주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero LCD Screen Replacement
필요한 것
    1. GoPro Hero LCD Screen Replacement, Casing: 1 단계, 이미지 1개 중 1개
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      댓글 쓰기
    2. GoPro Hero LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      댓글 쓰기
    3. GoPro Hero LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      댓글 쓰기
    4. GoPro Hero LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      댓글 쓰기
    5. GoPro Hero LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      댓글 쓰기
    6. GoPro Hero LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully remove the motherboard and white plastic piece from the case.
      댓글 쓰기
    1. GoPro Hero LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 GoPro Hero LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      댓글 쓰기
    2. GoPro Hero LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Separate the motherboard from the white piece of plastic.
      댓글 쓰기
    3. GoPro Hero LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
      댓글 쓰기
    4. GoPro Hero LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 GoPro Hero LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Separate the LCD screen from the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
River Drake
회원 가입일: 04/02/15
1,065 평판
안내서 5개를 작성함
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개를 작성함
3가이드 댓글
Where do you buy the replacement lcd
Anthony Volatile - 답글 공유
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - 답글 공유
I can find the screen but is it compatible with the Hero+
Brian Casado - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 39
지난 30일: 144
전체 시간: 27,389
