주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero Lens Replacement
필요한 것
  1. GoPro Hero Lens Replacement, Casing: 1 단계, 이미지 1개 중 1개
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    댓글 쓰기
  2. GoPro Hero Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    댓글 쓰기
  3. GoPro Hero Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    댓글 쓰기
  4. GoPro Hero Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    댓글 쓰기
  5. GoPro Hero Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
    댓글 쓰기
  6. GoPro Hero Lens Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the motherboard and white plastic piece from the case.
    댓글 쓰기
  7. GoPro Hero Lens Replacement, Lens: 7 단계, 이미지 1개 중 1개
    • Remove the four screws from the lens.
    • These screws are smaller than the ones removed from the white plastic piece.
    댓글 쓰기
  8. GoPro Hero Lens Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the lens from the case.
    댓글 쓰기
결론
To reassemble your device, follow the instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
River Drake
회원 가입일: 04/02/15
1,065 평판
안내서 5개를 작성함
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개를 작성함
1가이드 댓글
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 72
전체 시간: 14,147
