주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
필요한 것
    1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: 1 단계, 이미지 1개 중 1개
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      댓글 쓰기
    2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 2 단계, 이미지 1개 중 1개
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      댓글 쓰기
    3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 3 단계, 이미지 1개 중 1개
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      댓글 쓰기
    4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 4 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      댓글 쓰기
    5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 5 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      댓글 쓰기
    6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 6 단계, 이미지 1개 중 1개
      • Carefully remove the motherboard and white plastic piece from the case.
      댓글 쓰기
    1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: 7 단계, 이미지 2개 중 1개 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: 7 단계, 이미지 2개 중 2개
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      댓글 쓰기
    2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 8 단계, 이미지 1개 중 1개
      • Remove the two screws located on each side of the board with a Phillips screwdriver.
      • The screws go through an L metal bracket that will come off with the screws.
      댓글 쓰기
    3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 9 단계, 이미지 1개 중 1개
      • Separate the daughter board from the white plastic piece.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
River Drake
회원 가입일: 04/02/15
1,065 평판
안내서 5개를 작성함
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개를 작성함
4가이드 댓글
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - 답글 공유
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - 답글 공유
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - 답글 공유
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 86
전체 시간: 5,703
