주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero3+ Black Edition Camera Lens Replacement
필요한 것
    1. GoPro Hero3+ Black Edition Camera Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Pull the tab on the back of the device to release the back cover. It should come right off.
      • The device pictured does not include the back cover.
      댓글 쓰기
    2. GoPro Hero3+ Black Edition Camera Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Use the battery tab to pull the battery out of the device.
      댓글 쓰기
      • Remove the battery from the slot.
      댓글 쓰기
    1. GoPro Hero3+ Black Edition Camera Lens Replacement, Front Face Plate: 4 단계, 이미지 2개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement, Front Face Plate: 4 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
      • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
      댓글 쓰기
    1. GoPro Hero3+ Black Edition Camera Lens Replacement, Image Sensor: 5 단계, 이미지 3개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement, Image Sensor: 5 단계, 이미지 3개 중 2개 GoPro Hero3+ Black Edition Camera Lens Replacement, Image Sensor: 5 단계, 이미지 3개 중 3개
      • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
      • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
      • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
      댓글 쓰기
    2. GoPro Hero3+ Black Edition Camera Lens Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
      댓글 쓰기
    3. GoPro Hero3+ Black Edition Camera Lens Replacement: 7 단계, 이미지 1개 중 1개
      • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
      • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
      댓글 쓰기
    4. GoPro Hero3+ Black Edition Camera Lens Replacement: 8 단계, 이미지 1개 중 1개
      • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
      • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
      댓글 쓰기
    5. GoPro Hero3+ Black Edition Camera Lens Replacement: 9 단계, 이미지 2개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement: 9 단계, 이미지 2개 중 2개
      • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
      • Remove the image sensor from the motherboard assembly.
      댓글 쓰기
    1. GoPro Hero3+ Black Edition Camera Lens Replacement, microSD and Accessory Board: 10 단계, 이미지 1개 중 1개
      • Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
      댓글 쓰기
    2. GoPro Hero3+ Black Edition Camera Lens Replacement: 11 단계, 이미지 2개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement: 11 단계, 이미지 2개 중 2개
      • Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
      • The microSD/accessory board is ready to come off.
      댓글 쓰기
    1. GoPro Hero3+ Black Edition Camera Lens Replacement, Motherboard: 12 단계, 이미지 1개 중 1개
      • Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
      댓글 쓰기
    2. GoPro Hero3+ Black Edition Camera Lens Replacement: 13 단계, 이미지 3개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement: 13 단계, 이미지 3개 중 2개 GoPro Hero3+ Black Edition Camera Lens Replacement: 13 단계, 이미지 3개 중 3개
      • Use the spudger tool to disconnect the front LCD from the motherboard. Gently pull the ribbon cable out.
      • Gently pull the motherboard away from the midframe.
      댓글 쓰기
    1. GoPro Hero3+ Black Edition Camera Lens Replacement, Camera Lens: 14 단계, 이미지 2개 중 1개 GoPro Hero3+ Black Edition Camera Lens Replacement, Camera Lens: 14 단계, 이미지 2개 중 2개
      • Simply use your PH00 screwdriver to remove the last three screws, and the lens housing is ready to come off.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Fox
회원 가입일: 04/22/15
272 평판
안내서 1개를 작성함
Cal Poly, Team 6-15, Maness Spring 2015 Cal Poly, Team 6-15, Maness Spring 2015 회원
CPSU-MANESS-S15S6G15
4 회원들
안내서 13개를 작성함
1가이드 댓글
Hey, is there any lens to replace the original one you can recommend? I've seen prices from 15 to 80 Euro, basically everyone claiming the same features (170°).
Rick - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 4,558
