주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero3+ Silver Edition Image Sensor Replacement
필요한 것
  1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: 1 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push the tab on the back of the device left to remove the plate covering the battery.
    댓글 쓰기
  2. GoPro Hero3+ Silver Edition Image Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Use the strip of tape on the battery to remove the battery from the housing.
    댓글 쓰기
  3. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: 3 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    댓글 쓰기
  4. GoPro Hero3+ Silver Edition Image Sensor Replacement: 4 단계, 이미지 1개 중 1개
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    댓글 쓰기
  5. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: 5 단계, 이미지 3개 중 1개 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: 5 단계, 이미지 3개 중 2개 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: 5 단계, 이미지 3개 중 3개
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    댓글 쓰기
  6. GoPro Hero3+ Silver Edition Image Sensor Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Image Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    댓글 쓰기
  7. GoPro Hero3+ Silver Edition Image Sensor Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    댓글 쓰기
  8. GoPro Hero3+ Silver Edition Image Sensor Replacement: 8 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Image Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Patrick Cook
회원 가입일: 10/01/15
699 평판
안내서 3개를 작성함
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 회원
CPSU-MANESS-F15S5G8
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 34
전체 시간: 1,183
