주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero4 Black LCD Screen Replacement
필요한 것
  1. GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: 1 단계, 이미지 3개 중 1개 GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: 1 단계, 이미지 3개 중 2개 GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
    댓글 쓰기
  2. GoPro Hero4 Black LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 GoPro Hero4 Black LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
    댓글 쓰기
  3. GoPro Hero4 Black LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 GoPro Hero4 Black LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
    댓글 쓰기
  4. GoPro Hero4 Black LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 GoPro Hero4 Black LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 GoPro Hero4 Black LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
    댓글 쓰기
  5. GoPro Hero4 Black LCD Screen Replacement, LCD Screen: 5 단계, 이미지 2개 중 1개 GoPro Hero4 Black LCD Screen Replacement, LCD Screen: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Open the clip that is located on the motherboard
    • Use a pair of tweezers to pull the ribbon from the clip
    댓글 쓰기
  6. GoPro Hero4 Black LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 GoPro Hero4 Black LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 GoPro Hero4 Black LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Before you start this step flip the section holding the LCD screen over
    • Place the iOpener on the LCD screen cover to release the glue
    • Lift the covering of the LCD screen cover off with a pair of tweezers
    댓글 쓰기
  7. GoPro Hero4 Black LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 GoPro Hero4 Black LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to lift the ribbon through the opening and lift all the way up to the LCD screen
    • A section of our LCD screen ribbon was broken so it is not visible from the image.
    댓글 쓰기
  8. GoPro Hero4 Black LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 GoPro Hero4 Black LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Place the iOpener on the LCD screen to remove the glue
    • Use a pair of tweezers to left the LCD screen off the device
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jeffrey Goethe
회원 가입일: 02/20/17
674 평판
안내서 3개를 작성함
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G1
4 회원들
안내서 12개를 작성함
4가이드 댓글
Bonjour , est ce que je peux installer un écran LCD sur une hero 4 silver ( sans écran LCD d'origine ) . Je dispose d'une hero 4 black LCD HS . Merci de vos réponses. Sébastien
Coolsaet - 답글 공유
No, ce n'est malheureusement pas possible.
Der Zurechtweiser - 답글 공유
You got the screw locations on the front wrong. Bottom left is the shortest screw, where the battery compartment is. If you try putting one of the longer screws through their it'll bust into the battery compartment. Ask me how I know. And that's the one reason why I came to this, the one thing I couldn't remember.
fat_toni987 - 답글 공유
My GoPro Hero4 Black Button Won't Click After Screen Replacement
I did the GoPro Hero4 Black LCD Screen Replacement. The problem is, I don't get the button to click with the Midframe Housing on. Pressing the naked button works, but the mode plastic button doesn't work when placed above it, there is no clicking sound and no function.
Should I put a placeholder somewhere?
What could be the solution?
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 67
전체 시간: 8,874
