주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Home Sound Driver Replacement
필요한 것
    1. Google Home Sound Driver Replacement, Interconnect Cable: 1 단계, 이미지 3개 중 1개 Google Home Sound Driver Replacement, Interconnect Cable: 1 단계, 이미지 3개 중 2개 Google Home Sound Driver Replacement, Interconnect Cable: 1 단계, 이미지 3개 중 3개
      • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
      • Pull off the Google Home’s magnetically attached base and set it aside.
      • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
      • After all four screws are out, pop the lid off the device to open the capsule.
      댓글 쓰기
    2. Google Home Sound Driver Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Carefully remove the interconnect cable using a pair of tweezers.
      댓글 쓰기
    1. Google Home Sound Driver Replacement, Mute Button Switch: 3 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement, Mute Button Switch: 3 단계, 이미지 2개 중 2개
      • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
      댓글 쓰기
    2. Google Home Sound Driver Replacement: 4 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement: 4 단계, 이미지 2개 중 2개
      • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
      • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
      댓글 쓰기
    1. Google Home Sound Driver Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
      • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
      • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
      댓글 쓰기
    2. Google Home Sound Driver Replacement: 6 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement: 6 단계, 이미지 2개 중 2개
      • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
      • Remove the motherboard.
      댓글 쓰기
    1. Google Home Sound Driver Replacement, Sound Driver: 7 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement, Sound Driver: 7 단계, 이미지 2개 중 2개
      • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
      • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
      댓글 쓰기
    2. Google Home Sound Driver Replacement: 8 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement: 8 단계, 이미지 2개 중 2개
      • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
      댓글 쓰기
    3. Google Home Sound Driver Replacement: 9 단계, 이미지 2개 중 1개 Google Home Sound Driver Replacement: 9 단계, 이미지 2개 중 2개
      • Pull apart the black casing to reveal the sound driver.
      • Remove the sound driver.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gabe Hyun
회원 가입일: 04/17/18
847 평판
안내서 4개를 작성함
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 회원
CPSU-MANESS-S18S24G11
4 회원들
안내서 15개를 작성함
4가이드 댓글
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - 답글 공유
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - 답글 공유
Looking for replacement speaker, where do I find?
Corey Anderson - 답글 공유
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 39
전체 시간: 3,060
