주요 콘텐츠로 건너뛰기
Google Pixel 4 XL Charging Assembly Replacement
필요한 것
  1. Google Pixel 4 XL Charging Assembly Replacement, Remove the SIM card tray: 1 단계, 이미지 1/3 Google Pixel 4 XL Charging Assembly Replacement, Remove the SIM card tray: 1 단계, 이미지 2/3 Google Pixel 4 XL Charging Assembly Replacement, Remove the SIM card tray: 1 단계, 이미지 3/3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 XL Charging Assembly Replacement, Heat the back panel glass: 2 단계, 이미지 1/1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 XL Charging Assembly Replacement, Apply a suction cup: 3 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement, Apply a suction cup: 3 단계, 이미지 2/2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 XL Charging Assembly Replacement, Insert an opening pick: 4 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement, Insert an opening pick: 4 단계, 이미지 2/2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 XL Charging Assembly Replacement, Begin to slice the adhesive: 5 단계, 이미지 1/3 Google Pixel 4 XL Charging Assembly Replacement, Begin to slice the adhesive: 5 단계, 이미지 2/3 Google Pixel 4 XL Charging Assembly Replacement, Begin to slice the adhesive: 5 단계, 이미지 3/3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 XL Charging Assembly Replacement, Slice the lefthand-side adhesive: 6 단계, 이미지 1/1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 XL Charging Assembly Replacement: 7 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 7 단계, 이미지 2/2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 XL Charging Assembly Replacement: 8 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 8 단계, 이미지 2/2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 XL Charging Assembly Replacement, Slice righthand-side adhesive: 9 단계, 이미지 1/1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 XL Charging Assembly Replacement: 10 단계, 이미지 1/3 Google Pixel 4 XL Charging Assembly Replacement: 10 단계, 이미지 2/3 Google Pixel 4 XL Charging Assembly Replacement: 10 단계, 이미지 3/3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 XL Charging Assembly Replacement, Slice the top-side adhesive: 11 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement, Slice the top-side adhesive: 11 단계, 이미지 2/2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 XL Charging Assembly Replacement, Lift up the back panel: 12 단계, 이미지 1/3 Google Pixel 4 XL Charging Assembly Replacement, Lift up the back panel: 12 단계, 이미지 2/3 Google Pixel 4 XL Charging Assembly Replacement, Lift up the back panel: 12 단계, 이미지 3/3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 XL Charging Assembly Replacement: 13 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 13 단계, 이미지 2/2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 XL Charging Assembly Replacement, Disconnect the battery: 14 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the four T3 Torx screws securing the battery connector shield:
    • One 1.8 mm screw
    • One 4.1 mm screw
    • One 4.4 mm shouldered screw
    • One 4.0 mm shouldered screw
  15. Google Pixel 4 XL Charging Assembly Replacement: 15 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 15 단계, 이미지 2/2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 XL Charging Assembly Replacement: 16 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 16 단계, 이미지 2/2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 XL Charging Assembly Replacement: 17 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 17 단계, 이미지 2/2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 XL Charging Assembly Replacement, Disconnect the back panel connector: 18 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
  19. Google Pixel 4 XL Charging Assembly Replacement: 19 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 19 단계, 이미지 2/2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 XL Charging Assembly Replacement: 20 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 20 단계, 이미지 2/2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 XL Charging Assembly Replacement, Remove the back panel: 21 단계, 이미지 1/1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 XL Charging Assembly Replacement, Remove the battery's adhesive pull tabs: 22 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement, Remove the battery's adhesive pull tabs: 22 단계, 이미지 2/2
    • Use blunt tweezers to lift up the battery adhesive pull tabs so you can more easily grip them with your fingers.
    • The battery is held in place with three separate stretch adhesive strips, which are connected to a single black pull tab. You can try to pull all three strips out together, but it is easier to cut the black pull tab where it is notched and pull each strip out individually.
  23. Google Pixel 4 XL Charging Assembly Replacement: 23 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 23 단계, 이미지 2/2
    • Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around a spudger and continue pulling.
    • Continue firmly pulling up on the adhesive strip with constant force, spinning the spudger every so often to keep the exposed section of the pull tab as short as possible.
    • This may take a lot of force.
    • These adhesive pull tabs are very prone to snapping in half during this process. Try pulling as slowly as possible.
    • If the adhesive pull tabs are not stretching, you can fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
    • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
  24. Google Pixel 4 XL Charging Assembly Replacement, Remove the battery: 24 단계, 이미지 1/3 Google Pixel 4 XL Charging Assembly Replacement, Remove the battery: 24 단계, 이미지 2/3 Google Pixel 4 XL Charging Assembly Replacement, Remove the battery: 24 단계, 이미지 3/3
    • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
    • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
    • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
  25. Google Pixel 4 XL Charging Assembly Replacement: 25 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 25 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Don't reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Lift the battery up, away from the phone to remove it.
    • To install a replacement battery:
    • Remove any remaining adhesive from the battery well.
    • If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
    • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
    • Lay the battery in place and press firmly.
    • Disconnect the battery connector from its motherboard socket and resume re-assembly.
  26. Google Pixel 4 XL Charging Assembly Replacement, Remove the loudspeaker: 26 단계, 이미지 1/1
    • Remove the three T3 Torx screws securing the loudspeaker:
    • One 4.1 mm screw
    • One 2.7 mm screw
  27. Google Pixel 4 XL Charging Assembly Replacement: 27 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 27 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Use a pair of tweezers to remove the loudspeaker.
    • Before you install a replacement loudspeaker, check the adhesive gasket:
    • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
    • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
  28. Google Pixel 4 XL Charging Assembly Replacement, Disconnect the charging cable connector: 28 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
  29. Google Pixel 4 XL Charging Assembly Replacement: 29 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 29 단계, 이미지 2/2
    • Use a pair of tweezer to remove the display connector cover.
  30. Google Pixel 4 XL Charging Assembly Replacement: 30 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 30 단계, 이미지 2/2
    • Using the pointed end of a spudger, disconnect the charging cable connector by prying it straight up from the motherboard.
  31. Google Pixel 4 XL Charging Assembly Replacement, Isolate the charging assembly: 31 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement, Isolate the charging assembly: 31 단계, 이미지 2/2
    • Disconnect the antenna press connector from the charging assembly.
  32. Google Pixel 4 XL Charging Assembly Replacement: 32 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 32 단계, 이미지 2/2
    • Disconnect the vibration and bottom microphone connectors from the charging assembly.
  33. Google Pixel 4 XL Charging Assembly Replacement: 33 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement: 33 단계, 이미지 2/2
    • Use the pointed end of a spudger to pry up and disconnect the black antenna cable from its socket on the motherboard.
  34. Google Pixel 4 XL Charging Assembly Replacement, Remove the charging assembly: 34 단계, 이미지 1/2 Google Pixel 4 XL Charging Assembly Replacement, Remove the charging assembly: 34 단계, 이미지 2/2
    • Peel back the ribbon cable that's secured to the phone's frame. It's secured with some light adhesive.
  35. Google Pixel 4 XL Charging Assembly Replacement: 35 단계, 이미지 1/3 Google Pixel 4 XL Charging Assembly Replacement: 35 단계, 이미지 2/3 Google Pixel 4 XL Charging Assembly Replacement: 35 단계, 이미지 3/3
    • Remove the charging assembly.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 9명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
114,056 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,198개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 28
30일 전: 107
전체 시간: 9,224
