주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 8a Back Cover Replacement
필요한 것
  1. Google Pixel 8a Back Cover Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 3개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8a Back Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
    • The back cover is secured with adhesive around the perimeter and near the cameras. To avoid damaging your phone's internals, note the following:
    • Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
    • Don't insert your tool under the edges of the camera bump.
  3. Google Pixel 8a Back Cover Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 3개
    • Your opening tool has a flat end and a curved end. During the opening procedure, use the flat end and angle it so the tool's sharp edge points upward.
    • Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
  4. Google Pixel 8a Back Cover Replacement, Separate the perimeter adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement, Separate the perimeter adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement, Separate the perimeter adhesive: 4 단계, 이미지 3개 중 3개
    • Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
  5. Google Pixel 8a Back Cover Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Slide your opening tool around the bottom right corner and up the right edge, stopping at the bottom of the camera bump.
    • Remove your opening tool from under the back cover.
  6. Google Pixel 8a Back Cover Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Insert your opening tool under the top right corner of the back cover, just above the camera bump.
    • Slide your opening tool along the top edge, stopping at the top left corner just above the camera bump.
  7. Google Pixel 8a Back Cover Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Insert your opening tool under the left edge of the back cover, just below the camera bump.
    • Slide your opening tool down the left edge to separate the adhesive.
  8. Google Pixel 8a Back Cover Replacement, Separate the camera bump adhesive: 8 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement, Separate the camera bump adhesive: 8 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement, Separate the camera bump adhesive: 8 단계, 이미지 3개 중 3개
    • A strip of adhesive above the camera bump secures the top edge of the back cover.
    • Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
    • You can insert the opening pick more than 3 mm along the top edge.
    • Slide the pick to the right, stopping when you reach the right edge of the cameras.
  9. Google Pixel 8a Back Cover Replacement: 9 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement: 9 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement: 9 단계, 이미지 3개 중 3개
    • A final strip of adhesive below the camera bump secures the back cover.
    • Insert the flat edge of an opening pick under the back cover, just below the camera bump.
    • Insert a second opening pick in the same spot on the other side.
  10. Google Pixel 8a Back Cover Replacement: 10 단계, 이미지 3개 중 1개 Google Pixel 8a Back Cover Replacement: 10 단계, 이미지 3개 중 2개 Google Pixel 8a Back Cover Replacement: 10 단계, 이미지 3개 중 3개
    • Pry up simultaneously with both picks and apply constant pressure to separate the final piece of adhesive securing the back cover.
    • Be careful not to bend the back cover. If the adhesive feels stubborn, rotate the cover side-to-side to further loosen the adhesive.
    • If the adhesive isn't separating, you can lightly heat the back cover just below the camera bump with a hair dryer or iOpener to soften the adhesive.
  11. Google Pixel 8a Back Cover Replacement, Remove the back cover: 11 단계, 이미지 2개 중 1개 Google Pixel 8a Back Cover Replacement, Remove the back cover: 11 단계, 이미지 2개 중 2개
    • Remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back cover.
결론
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
160,379 평판
안내서 1,045개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,996개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 60
지난 30일: 298
전체 시간: 5,972
