주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel C Keyboard Replacement
필요한 것
    1. Google Pixel C Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
      • Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
      • When reattaching the plastic strip, apply adhesive to ensure that the strip will stay securely in place.
      댓글 쓰기
    2. Google Pixel C Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Google Pixel C Keyboard Replacement: 2 단계, 이미지 2개 중 2개
      • Use a medium plastic opening tool to lift the black plastic strip from the lower edge of the keyboard.
      댓글 쓰기
    3. Google Pixel C Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Google Pixel C Keyboard Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the four 3.1mm Phillips #000 screws that hold the keyboard to the back plate.
      • Using the Phillips #000 Screwdriver, remove the screws from the keyboard.
      • The screws are reverse threaded, so turn them clockwise to remove them.
      댓글 쓰기
    4. Google Pixel C Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Orient the keyboard so that the side with the keys is facedown on the table.
      • Use either an iFixit iOpener OR a heat gun to melt the adhesive that holds the top half of the keyboard to the bottom.
      • When using a heat gun for removal, only heat the backside of the keyboard to avoid warping the keys.
      댓글 쓰기
    5. Google Pixel C Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel C Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel C Keyboard Replacement: 5 단계, 이미지 3개 중 3개
      • Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
      • If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
      • Be mindful of the amount of force applied to avoid snapping the keyboard.
      • It will be necessary to use adhesive to ensure that the keyboard is securely in place during reassembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Makenzie Kamei
회원 가입일: 04/26/17
137 평판
안내서 1개를 작성함
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G4
4 회원들
안내서 11개를 작성함
1가이드 댓글
Uninstall a Pixel c's keyboard case's battery system,The Battery is out of life, but the case cost Pixel c's power while closed. No suitable battery to replace temporarily. Use a Hot Gun with higher temparature but control the temparature not too high then you will easily peal off the skin but no any broken and finally you can adhere it back to normal.Finished and accept. Now I just use the case as a case only and no need consider it cost the power.
bgzhang - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 2,480
