주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel C Speaker Replacement
필요한 것
  1. Google Pixel C Speaker Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
    댓글 쓰기
  2. Google Pixel C Speaker Replacement: 2 단계, 이미지 2개 중 1개 Google Pixel C Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
    댓글 쓰기
  3. Google Pixel C Speaker Replacement: 3 단계, 이미지 2개 중 1개 Google Pixel C Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
    댓글 쓰기
  4. Google Pixel C Speaker Replacement: 4 단계, 이미지 2개 중 1개 Google Pixel C Speaker Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
    댓글 쓰기
  5. Google Pixel C Speaker Replacement, Speaker: 5 단계, 이미지 1개 중 1개
    • Locate the thin black speakers along the right and left sides of the tablet.
    • The longer speaker is secured by two different types of screws, while the shorter one is secured by two of the same type of screw.
    댓글 쓰기
  6. Google Pixel C Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #000 screwdriver to remove the three 4.2mm screws
    • Use the same screwdriver to remove the 2.5mm screw as well.
    댓글 쓰기
  7. Google Pixel C Speaker Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel C Speaker Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel C Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the two circular metal caps that are attached to the short speaker via a small cable and gently pull them out of the device
    • Locate and detach the third cable cap that is attached to the longer speaker.
    • The third cable runs along the upper edge of the device, and is secured down with adhesive.
    댓글 쓰기
  8. Google Pixel C Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Slide both speakers out from the edges of the device.
    댓글 쓰기
  9. Google Pixel C Speaker Replacement: 9 단계, 이미지 3개 중 1개 Google Pixel C Speaker Replacement: 9 단계, 이미지 3개 중 2개 Google Pixel C Speaker Replacement: 9 단계, 이미지 3개 중 3개
    • Locate the red and black twisted wires.
    • Use a spudger to pry under the cable and pop it free from the attachment, fully detaching the speaker from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Isabelle Tang
회원 가입일: 04/26/17
225 평판
안내서 2개를 작성함
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G4
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 42
전체 시간: 1,268
