주요 콘텐츠로 건너뛰기
Google Pixel Watch 4 Screen Replacement
필요한 것
  1. Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: 1 단계, 이미지 3개 중 3개
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
  2. Google Pixel Watch 4 Screen Replacement, Remove the watch bands: 2 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the watch bands: 2 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Remove the watch bands: 2 단계, 이미지 3개 중 3개
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
  3. Google Pixel Watch 4 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
  4. Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: 4 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: 4 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: 4 단계, 이미지 3개 중 3개
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
  5. Google Pixel Watch 4 Screen Replacement, Separate the back sensor glass: 5 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Separate the back sensor glass: 5 단계, 이미지 2개 중 2개
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
  6. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 6 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 6 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 6 단계, 이미지 3개 중 3개
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
  7. Google Pixel Watch 4 Screen Replacement, Remove the vibration motor screws: 7 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the vibration motor screws: 7 단계, 이미지 2개 중 2개
    • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
  8. Google Pixel Watch 4 Screen Replacement, Remove the vibration motor: 8 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the vibration motor: 8 단계, 이미지 2개 중 2개
  9. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 9 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 9 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 9 단계, 이미지 3개 중 3개
    • Gently flip the back sensor glass over the crown-side of the watch.
  10. Google Pixel Watch 4 Screen Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, use the point of a spudger to press down and reconnect the press connector.
    • This can be tricky, and may take a few tries.
    • If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
  11. Google Pixel Watch 4 Screen Replacement, Remove the battery screws: 11 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the battery screws: 11 단계, 이미지 2개 중 2개
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
  12. Google Pixel Watch 4 Screen Replacement, Remove the battery: 12 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the battery: 12 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Remove the battery: 12 단계, 이미지 3개 중 3개
    • Remove the battery.
  13. Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket screws: 13 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket screws: 13 단계, 이미지 2개 중 2개
    • Use a Torx Plus 1IP screwdriver to remove the two 2.0 mm‑long screws seucuring the screen cable bracket.
  14. Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: 14 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: 14 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: 14 단계, 이미지 3개 중 3개
    • Use tweezers to flip the bracket up and slowly peel it off the connector, being careful not to damage the tape.
    • During reassembly, apply the tape to the outer press connector before flipping the bracket over and into place.
  15. Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: 15 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: 15 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: 15 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap in the two screen cable press connectors.
    • Twist the spudger to disconnect the cables.
    • During reassembly, line the press connectors up and pinch them together to connect them.
  16. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 16 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 16 단계, 이미지 2개 중 2개
    • Gently flip the back glass over the side of the watch opposite the crown.
  17. Google Pixel Watch 4 Screen Replacement, Remove the screen screws: 17 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the screen screws: 17 단계, 이미지 2개 중 2개
    • Remove the four screws securing the display:
    • One 5.1 mm‑long Torx Plus 2IP screw
    • Two 3.3 mm‑long Torx Plus 2IP screws
    • One 4.2 mm‑long Torx Plus 5IP standoff screw
    • During reassembly, push down on the frame while installing the screws to make sure they're threading into their holes on the display.
  18. Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: 18 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: 18 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: 18 단계, 이미지 3개 중 3개
    • Flip the back sensor glass into place and flip your watch over so the screen faces up.
  19. Google Pixel Watch 4 Screen Replacement, Separate the screen: 19 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Screen Replacement, Separate the screen: 19 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger in the seam between the screen and frame and twist the spudger to separate the screen.
    • The display seals with an O-ring and might "pop" up once released.
  20. Google Pixel Watch 4 Screen Replacement, Remove the screen: 20 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, Remove the screen: 20 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, Remove the screen: 20 단계, 이미지 3개 중 3개
    • Lift the display up and carefully guide the screen cable out of its cutout to remove the screen.
    • During reassembly, feed the screen cable through its cutout until you can grip it with your fingers on the opposite side, then gently pull it through.
  21. Google Pixel Watch 4 Screen Replacement, O-ring installation: 21 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Screen Replacement, O-ring installation: 21 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Screen Replacement, O-ring installation: 21 단계, 이미지 3개 중 3개
    • If you plan to reuse the existing O-ring, be gentle when handling it—especially with sharp tweezers. Even a small indent may compromise the watch's water and dust resistance.
    • Use a pair of tweezers to remove the screen O‑ring—it will either be stuck to the frame or the underside of the screen.
    • If the O‑ring's groove is dirty or has gunk built up, apply a few drops of high‑concentration (>90%) isopropyl alcohol to a cotton swab and wipe it clean.
    • Avoid applying isopropyl alcohol to the magnetic strip on the side opposite the crown.
    • Place the new O‑ring loosely onto its lip on the frame.
    • Optionally, coat the O-ring in a small amount of O-ring-specific grease during installation.
    • Use your fingers to hold the O-ring in place and use a spudger to slide the opposite side up and over the lip until it seats in its groove.
    • Make sure the entire O‑ring is properly seated in its groove before continuing reassembly.
결론
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,052 평판
안내서 995개를 작성함
2가이드 댓글
Any idea when the replacement screens will be available to purchase?
nathan - 답글
When will the parts be available?
JR1 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 60
지난 7일: 477
지난 30일: 1,384
전체 시간: 3,217
