주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixelbook Battery (Back Panel) Replacement
필요한 것
  1. Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 1개 Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 2개 Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 3개
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    댓글 쓰기
  2. Google Pixelbook Battery (Back Panel) Replacement: 2 단계, 이미지 2개 중 1개 Google Pixelbook Battery (Back Panel) Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    댓글 쓰기
  3. Google Pixelbook Battery (Back Panel) Replacement: 3 단계, 이미지 3개 중 1개 Google Pixelbook Battery (Back Panel) Replacement: 3 단계, 이미지 3개 중 2개 Google Pixelbook Battery (Back Panel) Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    댓글 쓰기
  4. Google Pixelbook Battery (Back Panel) Replacement: 4 단계, 이미지 3개 중 1개 Google Pixelbook Battery (Back Panel) Replacement: 4 단계, 이미지 3개 중 2개 Google Pixelbook Battery (Back Panel) Replacement: 4 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    댓글 쓰기
  5. Google Pixelbook Battery (Back Panel) Replacement: 5 단계, 이미지 2개 중 1개 Google Pixelbook Battery (Back Panel) Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    댓글 쓰기
  6. Google Pixelbook Battery (Back Panel) Replacement: 6 단계, 이미지 2개 중 1개 Google Pixelbook Battery (Back Panel) Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the small, black casing by using the spudger to lift it up from its place.
    댓글 쓰기
  7. Google Pixelbook Battery (Back Panel) Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 33명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Megan Phillips
회원 가입일: 01/24/18
997 평판
안내서 1개를 작성함
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G1
4 회원들
안내서 9개를 작성함
25가이드 댓글
Question; with the rubber pads removed from the bottom…is there adhesive and if so, what’s best used to replace those and make it look factory stock again?
Fabian Aldo Santiago - 답글 공유
The rubber pads are fixed with double sided tape.
Kornel Schwarcz - 답글 공유
I just use Isopropyl alcohol to quickly and completely remove any adhesive residue and use an ample amount of JB Weld and Automotive Bondo to get the unit ready. Use a wet rag to remove any excess adhesive. Do not fo0rget to centrealize the Feline Eyelash right at the longest point of the night and invokie MARDUK!!! AAAHHRHRGH.
MyLil Hottie - 답글 공유
So yeah basic Chemistry coupled with the ‘Dark Arts’ have created a sustainable situation.!
Where did you buy the back case replacement part?
cartercapelli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 87
지난 30일: 336
전체 시간: 43,187
