주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixelbook Left Charging Port Replacement
필요한 것
  1. Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 1개 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 2개 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 3개
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    댓글 쓰기
  2. Google Pixelbook Left Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    댓글 쓰기
  3. Google Pixelbook Left Charging Port Replacement: 3 단계, 이미지 3개 중 1개 Google Pixelbook Left Charging Port Replacement: 3 단계, 이미지 3개 중 2개 Google Pixelbook Left Charging Port Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    댓글 쓰기
  4. Google Pixelbook Left Charging Port Replacement: 4 단계, 이미지 3개 중 1개 Google Pixelbook Left Charging Port Replacement: 4 단계, 이미지 3개 중 2개 Google Pixelbook Left Charging Port Replacement: 4 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    댓글 쓰기
  5. Google Pixelbook Left Charging Port Replacement: 5 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    댓글 쓰기
  6. Google Pixelbook Left Charging Port Replacement: 6 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the small, black casing by using the spudger to lift it up from its place.
    댓글 쓰기
  7. Google Pixelbook Left Charging Port Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    댓글 쓰기
  8. Google Pixelbook Left Charging Port Replacement, Left Charging Port: 8 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement, Left Charging Port: 8 단계, 이미지 2개 중 2개
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
    댓글 쓰기
  9. Google Pixelbook Left Charging Port Replacement: 9 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
    댓글 쓰기
  10. Google Pixelbook Left Charging Port Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
    댓글 쓰기
  11. Google Pixelbook Left Charging Port Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
    댓글 쓰기
  12. Google Pixelbook Left Charging Port Replacement: 12 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
    댓글 쓰기
  13. Google Pixelbook Left Charging Port Replacement: 13 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
    댓글 쓰기
  14. Google Pixelbook Left Charging Port Replacement: 14 단계, 이미지 1개 중 1개
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
    댓글 쓰기
  15. Google Pixelbook Left Charging Port Replacement: 15 단계, 이미지 2개 중 1개 Google Pixelbook Left Charging Port Replacement: 15 단계, 이미지 2개 중 2개
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alon Gary
회원 가입일: 01/24/18
576 평판
안내서 2개를 작성함
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G1
4 회원들
안내서 9개를 작성함
3가이드 댓글
Where to get replacemt charging port from please
kamil Szym - 답글 공유
Where can we get a replacement charging port for the Pixelbook Go 2 (i7)?
michaelnic - 답글 공유
Hi Michael, did you manage to find the charging port and replace it for the Pixelbook Go?
redshift galaxy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 39
전체 시간: 3,787
