주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Graco Secure Coverage LED Nursery Unit Replacement
필요한 것
    1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 1 단계, 이미지 3개 중 1개 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 1 단계, 이미지 3개 중 2개 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 1 단계, 이미지 3개 중 3개
      • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
      댓글 쓰기
    2. Graco Secure Coverage LED Nursery Unit Replacement: 2 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Nursery Unit Replacement: 2 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, pry and remove the battery cover carefully.
      • Remove the batteries using plastic opening tool.
      • Replace the batteries.
      댓글 쓰기
    1. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: 3 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: 3 단계, 이미지 2개 중 2개
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • Place the screws in a secure place.
      댓글 쓰기
    2. Graco Secure Coverage LED Nursery Unit Replacement: 4 단계, 이미지 1개 중 1개
      • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
      • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
      • Apply constant force carefully to avoid breaking any other plastic parts from the device.
      댓글 쓰기
    3. Graco Secure Coverage LED Nursery Unit Replacement: 5 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Nursery Unit Replacement: 5 단계, 이미지 2개 중 2개
      • Remove all three 7mm Phillips #1 screws from the mother board.
      • Place the screws in secure place.
      댓글 쓰기
    4. Graco Secure Coverage LED Nursery Unit Replacement: 6 단계, 이미지 3개 중 1개 Graco Secure Coverage LED Nursery Unit Replacement: 6 단계, 이미지 3개 중 2개 Graco Secure Coverage LED Nursery Unit Replacement: 6 단계, 이미지 3개 중 3개
      • Flip over the motherboard to look at the LED pins that are connected to it.
      • Solder off the LED pin from the motherboard.
      • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
      • Replace the LED.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Bryson Wolff
회원 가입일: 08/31/15
237 평판
안내서 2개를 작성함
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 391
