주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Graco Secure Coverage LED Parent Unit Replacement
필요한 것
    1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 1 단계, 이미지 3개 중 1개 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 1 단계, 이미지 3개 중 2개 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 1 단계, 이미지 3개 중 3개
      • Using plastic opening tool, pry and remove the battery lid.
      댓글 쓰기
    2. Graco Secure Coverage LED Parent Unit Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
      • Make sure that you disconnect the battery's wire before you remove the battery.
      댓글 쓰기
    1. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 3 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 3 단계, 이미지 2개 중 2개
      • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
      댓글 쓰기
    2. Graco Secure Coverage LED Parent Unit Replacement: 4 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Parent Unit Replacement: 4 단계, 이미지 2개 중 2개
      • Using opening plastic tool, pry the two grey cases from both sides of the device.
      • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
      • While pry off the grey cases, hold the device with your other hand to remove the cases
      댓글 쓰기
    3. Graco Secure Coverage LED Parent Unit Replacement: 5 단계, 이미지 1개 중 1개
      • Pry the edges of the device to separate the front and rare cases.
      • While prying the edges, hold the device with one hand to pull out each case a part.
      • Make sure you use a constant force, and the pushbuttons are pried off completely.
      댓글 쓰기
    4. Graco Secure Coverage LED Parent Unit Replacement: 6 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Parent Unit Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the 7mm Phillips #1 screw from the mother board.
      • Place the screw in a secure place.
      댓글 쓰기
    5. Graco Secure Coverage LED Parent Unit Replacement: 7 단계, 이미지 2개 중 1개 Graco Secure Coverage LED Parent Unit Replacement: 7 단계, 이미지 2개 중 2개
      • Flip over the motherboard.
      • Solder off LED from motherboard.
      • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
      • Replace the LED's
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Bryson Wolff
회원 가입일: 08/31/15
237 평판
안내서 2개를 작성함
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 24
전체 시간: 394
