주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Grip Tape Application
필요한 것
    1. Grip Tape Application, Grip Tape Application: 1 단계, 이미지 1개 중 1개
      • Peel off the paper backing from the sheet of grip tape.
      • Make sure you do not fold or wrinkle the grip tape.
      댓글 쓰기
    2. Grip Tape Application: 2 단계, 이미지 1개 중 1개
      • Center the sheet of grip tape evenly over the top of the skateboard deck.
      댓글 쓰기
    3. Grip Tape Application: 3 단계, 이미지 2개 중 1개 Grip Tape Application: 3 단계, 이미지 2개 중 2개
      • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
      댓글 쓰기
    4. Grip Tape Application: 4 단계, 이미지 2개 중 1개 Grip Tape Application: 4 단계, 이미지 2개 중 2개
      • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
      • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
      댓글 쓰기
    5. Grip Tape Application: 5 단계, 이미지 3개 중 1개 Grip Tape Application: 5 단계, 이미지 3개 중 2개 Grip Tape Application: 5 단계, 이미지 3개 중 3개
      • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
      • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
      • Be careful when using the utility knife and always keep it pointed away from yourself and others.
      댓글 쓰기
    6. Grip Tape Application: 6 단계, 이미지 1개 중 1개
      • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
      • Use caution when sanding as the grip tape can become heated.
      댓글 쓰기
    7. Grip Tape Application: 7 단계, 이미지 1개 중 1개
      • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
      댓글 쓰기
    8. Grip Tape Application: 8 단계, 이미지 2개 중 1개 Grip Tape Application: 8 단계, 이미지 2개 중 2개
      • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
      댓글 쓰기
결론
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jared Stine
회원 가입일: 10/05/12
800 평판
안내서 3개를 작성함
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 회원
CPSU-REGAN-F12S6G32
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 26
전체 시간: 8,541
