주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HMD Barbie Keypad Replacement
필요한 것
  1. HMD Barbie Keypad Replacement, Battery: 1 단계, 이미지 3개 중 1개 HMD Barbie Keypad Replacement, Battery: 1 단계, 이미지 3개 중 2개 HMD Barbie Keypad Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Fully power off the phone.
    • Remove the backplate by gripping it around the edges and pulling away from the phone.
    댓글 쓰기
  2. HMD Barbie Keypad Replacement: 2 단계, 이미지 3개 중 1개 HMD Barbie Keypad Replacement: 2 단계, 이미지 3개 중 2개 HMD Barbie Keypad Replacement: 2 단계, 이미지 3개 중 3개
    • Grip the battery from the top and pull away from the phone.
    • Ensure there is no swelling or damage to the battery. A swollen or damaged battery can be a fire hazard.
    댓글 쓰기
  3. HMD Barbie Keypad Replacement, Inner Backplate: 3 단계, 이미지 1개 중 1개
    • Remove the six 5mm screws using the T5 Torx screwdriver.
    댓글 쓰기
  4. HMD Barbie Keypad Replacement: 4 단계, 이미지 2개 중 1개 HMD Barbie Keypad Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the backplate using an opening tool.
    • Find an opening on the phone that makes it easiest to remove the backplate. Any side of the phone will work.
    댓글 쓰기
  5. HMD Barbie Keypad Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 HMD Barbie Keypad Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 HMD Barbie Keypad Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
    댓글 쓰기
  6. HMD Barbie Keypad Replacement: 6 단계, 이미지 3개 중 1개 HMD Barbie Keypad Replacement: 6 단계, 이미지 3개 중 2개 HMD Barbie Keypad Replacement: 6 단계, 이미지 3개 중 3개
    • The video ribbon is connected to the motherboard with a flat-topped, low profile connector. It is also secured with a piece of tape.
    • Use the tweezers to gently unstick the tape from the motherboard, leaving it stuck to the connector.
    • Use the tweezers to gently pull up on the connector until it disconnects from the motherboard.
    • Be gentle as you apply pressure on the tape and connector. These parts shouldn't take too much force to remove.
    댓글 쓰기
  7. HMD Barbie Keypad Replacement: 7 단계, 이미지 3개 중 1개 HMD Barbie Keypad Replacement: 7 단계, 이미지 3개 중 2개 HMD Barbie Keypad Replacement: 7 단계, 이미지 3개 중 3개
    • Beginning at the corner near where the video ribbon is located, insert an opening pick between the green motherboard and the pink housing.
    • Slowly work your way around the motherboard until it loosens enough that you can use your fingers to remove it.
    댓글 쓰기
  8. HMD Barbie Keypad Replacement, Keypad: 8 단계, 이미지 3개 중 1개 HMD Barbie Keypad Replacement, Keypad: 8 단계, 이미지 3개 중 2개 HMD Barbie Keypad Replacement, Keypad: 8 단계, 이미지 3개 중 3개
    • Push the keypad out of the outer casing from the front of the phone, outward.
    • You may now replace the keypad with a new one, inserting it where the old keypad was. Make sure to not obstruct any of the holes for screws with the keypad.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Hannah Carvalho
회원 가입일: 03/09/26
571 평판
안내서 5개를 작성함
UMass Dartmouth, Team 6-2, Botvin Spring 2026 UMass Dartmouth, Team 6-2, Botvin Spring 2026 회원
UMASSD-BOTVIN-S26S6G2
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 102
