주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HMD Fusion Screen Replacement
필요한 것
  1. HMD Fusion Screen Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    댓글 쓰기
  2. HMD Fusion Screen Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 3개
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
    댓글 쓰기
  3. HMD Fusion Screen Replacement, Remove the back cover screws: 3 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement, Remove the back cover screws: 3 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement, Remove the back cover screws: 3 단계, 이미지 3개 중 3개
    • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
    • Use your fingernails, or angled tweezers, to remove any stuck screws.
    • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
    댓글 쓰기
  4. HMD Fusion Screen Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • During the next four steps, the remaining back cover screws might fall out unexpectedly.
    • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
    댓글 쓰기
  5. HMD Fusion Screen Replacement, Unclip the back cover: 5 단계, 이미지 2개 중 1개 HMD Fusion Screen Replacement, Unclip the back cover: 5 단계, 이미지 2개 중 2개
    • Flip your phone over so the screen is facing up.
    • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
    댓글 쓰기
  6. HMD Fusion Screen Replacement: 6 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement: 6 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick along the left edge to begin unclipping the back cover.
    댓글 쓰기
  7. HMD Fusion Screen Replacement: 7 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement: 7 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
    댓글 쓰기
  8. HMD Fusion Screen Replacement: 8 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement: 8 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
    댓글 쓰기
  9. HMD Fusion Screen Replacement, Disconnect the battery: 9 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement, Disconnect the battery: 9 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement, Disconnect the battery: 9 단계, 이미지 3개 중 3개
    댓글 쓰기
  10. HMD Fusion Screen Replacement, Disconnect the power button: 10 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement, Disconnect the power button: 10 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement, Disconnect the power button: 10 단계, 이미지 3개 중 3개
    • Use a spudger to pry up and disconnect the power button press connector.
    • Remove the back cover.
    댓글 쓰기
  11. HMD Fusion Screen Replacement, Screen: 11 단계, 이미지 3개 중 1개 HMD Fusion Screen Replacement, Screen: 11 단계, 이미지 3개 중 2개 HMD Fusion Screen Replacement, Screen: 11 단계, 이미지 3개 중 3개
    • For the next step, you'll need to hold the graphite sheet out of the way of the display connector along the bottom of the motherboard.
    • Alternatively, you can use tape with light adhesive (such as painter's tape) to keep the graphite sheet out of the way.
    댓글 쓰기
  12. HMD Fusion Screen Replacement, Disconnect the display: 12 단계, 이미지 2개 중 1개 HMD Fusion Screen Replacement, Disconnect the display: 12 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the display press connector.
    • Pry under the right edge of the connector, as there are delicate surface‑mounted components to the left of it.
    댓글 쓰기
  13. HMD Fusion Screen Replacement, Separate the front camera: 13 단계, 이미지 2개 중 1개 HMD Fusion Screen Replacement, Separate the front camera: 13 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up the front camera from the frame and separate its adhesive.
    댓글 쓰기
  14. HMD Fusion Screen Replacement, Remove the screen screws: 14 단계, 이미지 2개 중 1개 HMD Fusion Screen Replacement, Remove the screen screws: 14 단계, 이미지 2개 중 2개
    • Use a T3 Torx screwdriver to remove the seven 3.3 mm‑long screws securing the screen:
    • Five screws on the motherboard
    • Two screws on the loudspeaker
    • One of the screws on the loudspeaker may be covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
    댓글 쓰기
  15. HMD Fusion Screen Replacement, Remove the screen: 15 단계, 이미지 2개 중 1개 HMD Fusion Screen Replacement, Remove the screen: 15 단계, 이미지 2개 중 2개
    • Lift the screen off the frame, making sure to thread the display cable through its slot.
    • Remove the screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
240,757 평판
안내서 1,180개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,572개를 작성함
5가이드 댓글
Wo kann ich ein Ersatzdisplay bestellen? (Bin aus der Schweiz)
Ivan Haedo - 답글 공유
Will the parts ever be in stock in Europe? Pointless to buy a repairable phone when you can't buy the parts
Ejrj - 답글 공유
In teh description you remove the screen, but Ifix send a sreen with a frame fixed to it. no way this is gona fit.
L Verheul - 답글 공유
Yes, the new screen has a frame attached to it. Just remove every screw on it an detach the frame carefully. I guess the frame supports the screen for transportation.
Robert Reiter - 답글 공유
Hello, I am in Portugal, can I buy the screen on this website?
Sand.barack - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 80
지난 30일: 373
전체 시간: 7,680
