주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HMDX Jam Battery Replacement
필요한 것
    1. HMDX Jam Battery Replacement, Opening speaker: 1 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      댓글 쓰기
    2. HMDX Jam Battery Replacement, remove rubber cover: 2 단계, 이미지 1개 중 1개
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      댓글 쓰기
    3. HMDX Jam Battery Replacement, Remove screws: 3 단계, 이미지 1개 중 1개
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      댓글 쓰기
    4. HMDX Jam Battery Replacement, Exposing Battery: 4 단계, 이미지 1개 중 1개
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      댓글 쓰기
    5. HMDX Jam Battery Replacement, Removing Battery: 5 단계, 이미지 1개 중 1개
      • Very gently remove the battery from the motherboard.
      댓글 쓰기
    6. HMDX Jam Battery Replacement, Remove battery attachments: 6 단계, 이미지 2개 중 1개 HMDX Jam Battery Replacement, Remove battery attachments: 6 단계, 이미지 2개 중 2개
      • Use a solder gun to remove the battery attachments from the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 42명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Prince Tendai Dzonga
회원 가입일: 02/05/15
680 평판
안내서 1개를 작성함
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G1
4 회원들
안내서 4개를 작성함
18가이드 댓글
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - 답글 공유
Did you ever find out where to purchase a new battery for it?
DJ Ethics - 답글 공유
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - 답글 공유
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - 답글 공유
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 109
전체 시간: 98,749
