주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HMDX Jam Plus Micro USB Jack Replacement
필요한 것
    1. HMDX Jam Plus  Micro USB Jack Replacement, Battery: 1 단계, 이미지 3개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement, Battery: 1 단계, 이미지 3개 중 2개 HMDX Jam Plus  Micro USB Jack Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Flip the device over so the bottom is facing up.
      • Use the large plastic opening tool to gently pry the rubber base from the device.
      • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
      댓글 쓰기
    2. HMDX Jam Plus  Micro USB Jack Replacement: 2 단계, 이미지 2개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
      댓글 쓰기
    3. HMDX Jam Plus  Micro USB Jack Replacement: 3 단계, 이미지 2개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement: 3 단계, 이미지 2개 중 2개
      • Gently separate the base from the rest of the device to reveal the battery and the main board.
      댓글 쓰기
    4. HMDX Jam Plus  Micro USB Jack Replacement: 4 단계, 이미지 3개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement: 4 단계, 이미지 3개 중 2개 HMDX Jam Plus  Micro USB Jack Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
      • Pull gently on the connectors to separate each one from the main board.
      • The battery is connected to board in the red socket and the speaker is connected in the white socket.
      댓글 쓰기
    5. HMDX Jam Plus  Micro USB Jack Replacement: 5 단계, 이미지 3개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement: 5 단계, 이미지 3개 중 2개 HMDX Jam Plus  Micro USB Jack Replacement: 5 단계, 이미지 3개 중 3개
      • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
      • Use the plastic opening tool to gently pry the battery free from the rest of the device.
      댓글 쓰기
    6. HMDX Jam Plus  Micro USB Jack Replacement: 6 단계, 이미지 2개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement: 6 단계, 이미지 2개 중 2개
      • Use new adhesive to secure battery back to the rest of the device.
      댓글 쓰기
    1. HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: 7 단계, 이미지 2개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: 7 단계, 이미지 2개 중 2개
      • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
      댓글 쓰기
    2. HMDX Jam Plus  Micro USB Jack Replacement: 8 단계, 이미지 2개 중 1개 HMDX Jam Plus  Micro USB Jack Replacement: 8 단계, 이미지 2개 중 2개
      • Carefully lift the main board away from the plastic.
      • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
      댓글 쓰기
    3. HMDX Jam Plus  Micro USB Jack Replacement: 9 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
      • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
      • Do not apply too much heat to the board as it may damage other portions of the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Maxwell Erickson
회원 가입일: 10/22/15
587 평판
안내서 4개를 작성함
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015 회원
MTUM-SHIRK-F15S10G3
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 19
전체 시간: 1,078
