주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 10 2101 Camera Replacement
필요한 것
  1. HP 10 2101 Camera Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Identify the SD card port.
    댓글 쓰기
  2. HP 10 2101 Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
    댓글 쓰기
  3. HP 10 2101 Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
    댓글 쓰기
  4. HP 10 2101 Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the back panel from the rest of the device.
    댓글 쓰기
  5. HP 10 2101 Camera Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Desolder the battery connectors from the motherboard.
    댓글 쓰기
  6. HP 10 2101 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the bright blue-green tabs to remove the battery from the rest of the device.
    • Pulling the tabs may not fully disconnect the battery from the metal display casing.
    댓글 쓰기
  7. HP 10 2101 Camera Replacement: 7 단계, 이미지 2개 중 1개 HP 10 2101 Camera Replacement: 7 단계, 이미지 2개 중 2개
    • If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
    • Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
    댓글 쓰기
  8. HP 10 2101 Camera Replacement, Camera: 8 단계, 이미지 1개 중 1개
    • Peel off the metal mesh tape with the plastic opening tool.
    댓글 쓰기
  9. HP 10 2101 Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Disconnect the zero insertion force (ZIF) cable. Use the tip of the spudger or your fingernail to flip up the small white locking flap. Then, you can safely pull the cable out.
    • Repeat this process for the second connection port.
    • Be sure to pry up on the hinged flap, not the connector socket.
    댓글 쓰기
  10. HP 10 2101 Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the front and back camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Bryce Harmsen
회원 가입일: 09/25/18
692 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 488
