주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-R263DX Disassembly
필요한 것
  1. HP 15-R263DX Disassembly, Battery: 1 단계, 이미지 2개 중 1개 HP 15-R263DX Disassembly, Battery: 1 단계, 이미지 2개 중 2개
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    댓글 쓰기
  2. HP 15-R263DX Disassembly, Optical Drive: 2 단계, 이미지 2개 중 1개 HP 15-R263DX Disassembly, Optical Drive: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    댓글 쓰기
  3. HP 15-R263DX Disassembly: 3 단계, 이미지 1개 중 1개
    • Gently slide the optical drive out of the side of the computer.
    댓글 쓰기
  4. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: 4 단계, 이미지 2개 중 1개 HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: 4 단계, 이미지 2개 중 2개
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    댓글 쓰기
  5. HP 15-R263DX Disassembly: 5 단계, 이미지 1개 중 1개
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    댓글 쓰기
  6. HP 15-R263DX Disassembly: 6 단계, 이미지 1개 중 1개
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    댓글 쓰기
  7. HP 15-R263DX Disassembly: 7 단계, 이미지 2개 중 1개 HP 15-R263DX Disassembly: 7 단계, 이미지 2개 중 2개
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    댓글 쓰기
  8. HP 15-R263DX Disassembly: 8 단계, 이미지 2개 중 1개 HP 15-R263DX Disassembly: 8 단계, 이미지 2개 중 2개
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    댓글 쓰기
  9. HP 15-R263DX Disassembly: 9 단계, 이미지 1개 중 1개
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dilan Johnson
회원 가입일: 02/12/18
723 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 46
전체 시간: 7,044
