주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-R263DX RAM Replacement
필요한 것
  1. HP 15-R263DX RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    댓글 쓰기
  2. HP 15-R263DX RAM Replacement, Optical Drive: 2 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement, Optical Drive: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    댓글 쓰기
  3. HP 15-R263DX RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Gently slide the optical drive out of the side of the computer.
    댓글 쓰기
  4. HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: 4 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: 4 단계, 이미지 2개 중 2개
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    댓글 쓰기
  5. HP 15-R263DX RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    댓글 쓰기
  6. HP 15-R263DX RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    댓글 쓰기
  7. HP 15-R263DX RAM Replacement: 7 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    댓글 쓰기
  8. HP 15-R263DX RAM Replacement: 8 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    댓글 쓰기
  9. HP 15-R263DX RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    댓글 쓰기
  10. HP 15-R263DX RAM Replacement, Hard Drive: 10 단계, 이미지 1개 중 1개
    • Remove the 2 black screws holding the hard drive to the computer frame.
    댓글 쓰기
  11. HP 15-R263DX RAM Replacement: 11 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement: 11 단계, 이미지 2개 중 2개
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
    댓글 쓰기
  12. HP 15-R263DX RAM Replacement, RAM: 12 단계, 이미지 1개 중 1개
    • Remove the 2 screws holding the motherboard into the case of the laptop.
    댓글 쓰기
  13. HP 15-R263DX RAM Replacement: 13 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the connections around the motherboard.
    • There is a connection hidden underneath the board. Remove this one last as you will need to lift the motherboard up to access it.
    댓글 쓰기
  14. HP 15-R263DX RAM Replacement: 14 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the screw holding the WiFi chip in place.
    • Slide the chip away from the motherboard and set it elsewhere inside the computer.
    댓글 쓰기
  15. HP 15-R263DX RAM Replacement: 15 단계, 이미지 1개 중 1개
    • Flip the motherboard over to access the underside revealing the RAM.
    댓글 쓰기
  16. HP 15-R263DX RAM Replacement: 16 단계, 이미지 2개 중 1개 HP 15-R263DX RAM Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the RAM chip by simultaneously prying the 2 spring clips away from the RAM.
    • The RAM will pop up when both clips are completely released.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Drake Hort
회원 가입일: 03/05/18
487 평판
안내서 3개를 작성함
1가이드 댓글
is this laptop model ram upgradable?
Gordon Velupillai - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 34
전체 시간: 1,880
