주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-ay052nr Fan Replacement
필요한 것
  1. HP 15-ay052nr Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
    댓글 쓰기
  2. HP 15-ay052nr Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
    댓글 쓰기
  3. HP 15-ay052nr Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
    댓글 쓰기
  4. HP 15-ay052nr Fan Replacement, Bottom Cover: 4 단계, 이미지 1개 중 1개
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
    댓글 쓰기
  5. HP 15-ay052nr Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
    댓글 쓰기
  6. HP 15-ay052nr Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
    댓글 쓰기
  7. HP 15-ay052nr Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
    댓글 쓰기
  8. HP 15-ay052nr Fan Replacement, Fan: 8 단계, 이미지 1개 중 1개
    • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
    • The base is the side by the heatsink, which is made of copper.
    댓글 쓰기
  9. HP 15-ay052nr Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Unplug the fan cable from the motherboard.
    • The fan can now be removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Stephanie Harms
회원 가입일: 01/13/19
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 756
