주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-d076nr Fan Replacement
필요한 것
  1. HP 15-d076nr Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
    댓글 쓰기
  2. HP 15-d076nr Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Move the right switch to the left so that the orange unlock symbol is showing.
    댓글 쓰기
  3. HP 15-d076nr Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Move the left switch to the right, covering the battery symbol, and hold.
    댓글 쓰기
  4. HP 15-d076nr Fan Replacement: 4 단계, 이미지 1개 중 1개
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
    댓글 쓰기
  5. HP 15-d076nr Fan Replacement, Wireless Card: 5 단계, 이미지 1개 중 1개
    • Re-orient the laptop, so that the back of the laptop faces away from you.
    댓글 쓰기
  6. HP 15-d076nr Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
    댓글 쓰기
  7. HP 15-d076nr Fan Replacement: 7 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
    댓글 쓰기
  8. HP 15-d076nr Fan Replacement: 8 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
    댓글 쓰기
  9. HP 15-d076nr Fan Replacement: 9 단계, 이미지 3개 중 1개 HP 15-d076nr Fan Replacement: 9 단계, 이미지 3개 중 2개 HP 15-d076nr Fan Replacement: 9 단계, 이미지 3개 중 3개
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
    댓글 쓰기
  10. HP 15-d076nr Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Slide the wireless card to the left to remove it from the socket.
    댓글 쓰기
  11. HP 15-d076nr Fan Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    • Locate the RAM in the exposed area.
    댓글 쓰기
  12. HP 15-d076nr Fan Replacement: 12 단계, 이미지 3개 중 1개 HP 15-d076nr Fan Replacement: 12 단계, 이미지 3개 중 2개 HP 15-d076nr Fan Replacement: 12 단계, 이미지 3개 중 3개
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
    댓글 쓰기
  13. HP 15-d076nr Fan Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the RAM.
    댓글 쓰기
  14. HP 15-d076nr Fan Replacement: 14 단계, 이미지 3개 중 1개 HP 15-d076nr Fan Replacement: 14 단계, 이미지 3개 중 2개 HP 15-d076nr Fan Replacement: 14 단계, 이미지 3개 중 3개
    • Locate the ribbon cables.
    • Pry up the black tabs on the connectors and disconnect both of the ribbon cables.
    댓글 쓰기
  15. HP 15-d076nr Fan Replacement: 15 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Locate the DVD drive screw.
    • Remove the Phillips PM2.5×6.5 screw using a Phillips #0 screwdriver.
    • Continue using a Phillips #0 screwdriver for the rest of this guide, and subsequent guides.
    • Take the screw and place it in a container so as to not lose it.
    댓글 쓰기
  16. HP 15-d076nr Fan Replacement: 16 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 16 단계, 이미지 2개 중 2개
    • Push down the tab that is located by the DVD drive screw.
    • Take the DVD drive in one hand, and using the plastic spludger, push the tab down, and out.
    댓글 쓰기
  17. HP 15-d076nr Fan Replacement: 17 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the fourteen Phillips PM2.5×6.0 screws, and place them in a separate container.
    댓글 쓰기
  18. HP 15-d076nr Fan Replacement: 18 단계, 이미지 3개 중 1개 HP 15-d076nr Fan Replacement: 18 단계, 이미지 3개 중 2개 HP 15-d076nr Fan Replacement: 18 단계, 이미지 3개 중 3개
    • Flip the laptop over, and open it as if you were using it.
    • Gently, remove the laptop cover/keyboard from the laptop using the plastic spudger.
    • When you remove the cover/keyboard, the laptop will become top heavy.
    댓글 쓰기
  19. HP 15-d076nr Fan Replacement: 19 단계, 이미지 1개 중 1개
    • Disconnect the monitor cable, using the plastic spudger, and pry it upwards.
    • Pull the cable from its routing until it is free.
    댓글 쓰기
  20. HP 15-d076nr Fan Replacement: 20 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 20 단계, 이미지 2개 중 2개
    • Lift the black tabs, and disconnect the three ribbon cables.
    • Disconnect the red-black-white speaker cable located in the lower left corner.
    댓글 쓰기
  21. HP 15-d076nr Fan Replacement: 21 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the three Phillips PM2.5×4.0 screws on the card reader in the bottom left corner.
    • Place the screws in a separate container.
    • Remove the card reader.
    댓글 쓰기
  22. HP 15-d076nr Fan Replacement: 22 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 22 단계, 이미지 2개 중 2개
    • Remove the five Phillips PM2.5×5.0 screws on the motherboard.
    댓글 쓰기
  23. HP 15-d076nr Fan Replacement: 23 단계, 이미지 1개 중 1개
    • Remove the Phillips PM2.5×5.0 screw located on the fan, in the upper right corner.
    댓글 쓰기
  24. HP 15-d076nr Fan Replacement: 24 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement: 24 단계, 이미지 2개 중 2개
    • Carefully lift up the motherboard.
    • Do not completely remove the motherboard. Simply lift it. There is a black cable on the bottom of the motherboard that is anchoring it.
    댓글 쓰기
  25. HP 15-d076nr Fan Replacement: 25 단계, 이미지 1개 중 1개
    • Locate the cable on the underside of the motherboard, in its lower right corner.
    • Carefully grip the cable, and pull downward to remove it.
    댓글 쓰기
  26. HP 15-d076nr Fan Replacement: 26 단계, 이미지 1개 중 1개
    • Flip the motherboard over.
    댓글 쓰기
  27. HP 15-d076nr Fan Replacement: 27 단계, 이미지 1개 중 1개
    • Locate the charge port cable connection point on the motherboard.
    • Grab the charge port cable's connector, and wiggle it to remove it.
    • Set the board off to the side.
    댓글 쓰기
  28. HP 15-d076nr Fan Replacement, Fan: 28 단계, 이미지 2개 중 1개 HP 15-d076nr Fan Replacement, Fan: 28 단계, 이미지 2개 중 2개
    • Carefully loosen the four screws on the processor heat sink.
    • The screws do not come out. They are retained by the heat sink.
    댓글 쓰기
  29. HP 15-d076nr Fan Replacement: 29 단계, 이미지 1개 중 1개
    • Disconnect the red-yellow-blue-black cable, next to the fan, on the motherboard.
    • You may need to wiggle it
    댓글 쓰기
  30. HP 15-d076nr Fan Replacement: 30 단계, 이미지 1개 중 1개
    • Remove the fan.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Mohiuddin Baig
회원 가입일: 01/10/17
172 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 25
전체 시간: 912
