주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-d076nr Wireless Card Replacement
필요한 것
  1. HP 15-d076nr Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
    댓글 쓰기
  2. HP 15-d076nr Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Move the right switch to the left so that the orange unlock symbol is showing.
    댓글 쓰기
  3. HP 15-d076nr Wireless Card Replacement: 3 단계, 이미지 1개 중 1개
    • Move the left switch to the right, covering the battery symbol, and hold.
    댓글 쓰기
  4. HP 15-d076nr Wireless Card Replacement: 4 단계, 이미지 1개 중 1개
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
    댓글 쓰기
  5. HP 15-d076nr Wireless Card Replacement, Wireless Card: 5 단계, 이미지 1개 중 1개
    • Re-orient the laptop, so that the back of the laptop faces away from you.
    댓글 쓰기
  6. HP 15-d076nr Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
    댓글 쓰기
  7. HP 15-d076nr Wireless Card Replacement: 7 단계, 이미지 2개 중 1개 HP 15-d076nr Wireless Card Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
    댓글 쓰기
  8. HP 15-d076nr Wireless Card Replacement: 8 단계, 이미지 2개 중 1개 HP 15-d076nr Wireless Card Replacement: 8 단계, 이미지 2개 중 2개
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
    댓글 쓰기
  9. HP 15-d076nr Wireless Card Replacement: 9 단계, 이미지 3개 중 1개 HP 15-d076nr Wireless Card Replacement: 9 단계, 이미지 3개 중 2개 HP 15-d076nr Wireless Card Replacement: 9 단계, 이미지 3개 중 3개
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
    댓글 쓰기
  10. HP 15-d076nr Wireless Card Replacement: 10 단계, 이미지 1개 중 1개
    • Slide the wireless card to the left to remove it from the socket.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gabrielle Farren
회원 가입일: 01/12/17
161 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 785
