주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-g010dx Button Board Replacement
필요한 것
  1. HP 15-g010dx Button Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
    댓글 쓰기
  2. HP 15-g010dx Button Board Replacement: 2 단계, 이미지 1개 중 1개
    • Place your finger on the left latch and slide it towards the center of the laptop.
    댓글 쓰기
  3. HP 15-g010dx Button Board Replacement: 3 단계, 이미지 1개 중 1개
    • Pull on the battery to remove.
    댓글 쓰기
  4. HP 15-g010dx Button Board Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
    댓글 쓰기
  5. HP 15-g010dx Button Board Replacement: 5 단계, 이미지 1개 중 1개
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
    댓글 쓰기
  6. HP 15-g010dx Button Board Replacement: 6 단계, 이미지 1개 중 1개
    • Using the tool of your choice, gently pry up on the top of the keyboard.
    댓글 쓰기
  7. HP 15-g010dx Button Board Replacement: 7 단계, 이미지 1개 중 1개
    • Release the top of the keyboard.
    댓글 쓰기
  8. HP 15-g010dx Button Board Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
    댓글 쓰기
  9. HP 15-g010dx Button Board Replacement, Button Board: 9 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
    댓글 쓰기
  10. HP 15-g010dx Button Board Replacement: 10 단계, 이미지 1개 중 1개
    • Using the spudger, remove the two rubber feet that are located near the battery.
    댓글 쓰기
  11. HP 15-g010dx Button Board Replacement: 11 단계, 이미지 1개 중 1개
    • Now remove the two Phillips screws that are located below the rubber feet.
    댓글 쓰기
  12. HP 15-g010dx Button Board Replacement: 12 단계, 이미지 3개 중 1개 HP 15-g010dx Button Board Replacement: 12 단계, 이미지 3개 중 2개 HP 15-g010dx Button Board Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the optical drive by pulling it out by hand.
    댓글 쓰기
  13. HP 15-g010dx Button Board Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws inside the optical drive housing.
    댓글 쓰기
  14. HP 15-g010dx Button Board Replacement: 14 단계, 이미지 1개 중 1개
    • Disconnect the power button ribbon cable by lifting the connector.
    댓글 쓰기
  15. HP 15-g010dx Button Board Replacement: 15 단계, 이미지 1개 중 1개
    • Now disconnect the touch pad ribbon cable by lifting the connector.
    댓글 쓰기
  16. HP 15-g010dx Button Board Replacement: 16 단계, 이미지 3개 중 1개 HP 15-g010dx Button Board Replacement: 16 단계, 이미지 3개 중 2개 HP 15-g010dx Button Board Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the screws indicated by an arrow stamped into the metal.
    댓글 쓰기
  17. HP 15-g010dx Button Board Replacement: 17 단계, 이미지 1개 중 1개
    • Insert the spudger between the palmrest and the laptop body.
    댓글 쓰기
  18. HP 15-g010dx Button Board Replacement: 18 단계, 이미지 1개 중 1개
    • Lift up on palm rest, while working the spudger around the perimeter.
    댓글 쓰기
  19. HP 15-g010dx Button Board Replacement: 19 단계, 이미지 2개 중 1개 HP 15-g010dx Button Board Replacement: 19 단계, 이미지 2개 중 2개
    • Remove palm rest and flip it over.
    댓글 쓰기
  20. HP 15-g010dx Button Board Replacement: 20 단계, 이미지 2개 중 1개 HP 15-g010dx Button Board Replacement: 20 단계, 이미지 2개 중 2개
    • Release the cable connected to the button board.
    댓글 쓰기
  21. HP 15-g010dx Button Board Replacement: 21 단계, 이미지 2개 중 1개 HP 15-g010dx Button Board Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws securing the button board.
    댓글 쓰기
  22. HP 15-g010dx Button Board Replacement: 22 단계, 이미지 1개 중 1개
    • Remove button board.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Christopher
회원 가입일: 10/02/18
1,162 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 33
전체 시간: 705
