주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 2000 - 2D22DX Hard Drive Replacement
필요한 것
    1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
      댓글 쓰기
    2. HP 2000 - 2D22DX Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
      댓글 쓰기
    1. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
      • Loosen the Phillips #00 screw securing the RAM compartment cover.
      • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
      댓글 쓰기
    2. HP 2000 - 2D22DX Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
      • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
      • When unclipped completely, pull the compartment door out and away from the chassis.
      댓글 쓰기
    3. HP 2000 - 2D22DX Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 HP 2000 - 2D22DX Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
      • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
      • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
      • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
      댓글 쓰기
    4. HP 2000 - 2D22DX Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP 2000 - 2D22DX Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
      • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
      • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
      댓글 쓰기
    5. HP 2000 - 2D22DX Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP 2000 - 2D22DX Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP 2000 - 2D22DX Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
      • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
      • Lift the hard drive out and away from its socket in the plastic chassis.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Conor Most
회원 가입일: 04/14/14
2,778 평판
안내서 6개를 작성함
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 회원
CPSU-MANESS-S14S3G40
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 69
전체 시간: 15,728
