주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 2000 - 2D22DX RAM Replacement
필요한 것
    1. HP 2000 - 2D22DX RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
      댓글 쓰기
    2. HP 2000 - 2D22DX RAM Replacement: 2 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX RAM Replacement: 2 단계, 이미지 2개 중 2개
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
      댓글 쓰기
    1. HP 2000 - 2D22DX RAM Replacement, RAM: 3 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX RAM Replacement, RAM: 3 단계, 이미지 2개 중 2개
      • After battery removal, the RAM compartment cover is exposed.
      • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
      • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
      • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
      댓글 쓰기
    2. HP 2000 - 2D22DX RAM Replacement: 4 단계, 이미지 2개 중 1개 HP 2000 - 2D22DX RAM Replacement: 4 단계, 이미지 2개 중 2개
      • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
      • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
      댓글 쓰기
    3. HP 2000 - 2D22DX RAM Replacement: 5 단계, 이미지 3개 중 1개 HP 2000 - 2D22DX RAM Replacement: 5 단계, 이미지 3개 중 2개 HP 2000 - 2D22DX RAM Replacement: 5 단계, 이미지 3개 중 3개
      • Move the black plastic film to the side to locate the RAM slots.
      • Locate the metal clips holding the RAM card in place.
      • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
      댓글 쓰기
    4. HP 2000 - 2D22DX RAM Replacement: 6 단계, 이미지 1개 중 1개
      • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
      • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Conor Most
회원 가입일: 04/14/14
2,778 평판
안내서 6개를 작성함
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 회원
CPSU-MANESS-S14S3G40
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 57
전체 시간: 4,361
