주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 225 G7 Battery Replacement
필요한 것
  1. HP 225 G7 Battery Replacement, Flip The Laptop Upside Down: 1 단계, 이미지 1개 중 1개
    • Firstly, flip the laptop upside down, so that you are looking at the bottom of it, and the hinge of the screen is facing away from you.
    댓글 쓰기
  2. HP 225 G7 Battery Replacement, Remove The Rubber "Leg": 2 단계, 이미지 2개 중 1개 HP 225 G7 Battery Replacement, Remove The Rubber "Leg": 2 단계, 이미지 2개 중 2개
    • Use the metal spuger (or another tool, just make sure its not too sharp) to remove the rubber "leg", all the way until it is completely removed.
    댓글 쓰기
  3. HP 225 G7 Battery Replacement, Remove The Upper Rubber "Leg": 3 단계, 이미지 1개 중 1개
    • Repeat for the top rubber.
    댓글 쓰기
  4. HP 225 G7 Battery Replacement, Unscrew: 4 단계, 이미지 3개 중 1개 HP 225 G7 Battery Replacement, Unscrew: 4 단계, 이미지 3개 중 2개 HP 225 G7 Battery Replacement, Unscrew: 4 단계, 이미지 3개 중 3개
    • Unscrew all the screws from the laptop, including the ones that were under the rubber "legs".
    • There should be 11 screws in total. (4 under the upper leg, 3 under the lower one, and 4 that were not under rubber).
    댓글 쓰기
  5. HP 225 G7 Battery Replacement, Start Inserting The Picks: 5 단계, 이미지 1개 중 1개
    • Carefully insert a pick under the touchpad of the laptop.
    댓글 쓰기
  6. HP 225 G7 Battery Replacement, Continue Inserting Picks: 6 단계, 이미지 1개 중 1개
    • Continue inserting picks all the way around the laptop.
    댓글 쓰기
  7. HP 225 G7 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Pull apart the cover and the body of the laptop.
    • If you find resistance, reduce the angle of the screen hinge, since the hinge might be "clamping" the cover.
    • If you still find resistance, check for any forgotten screws on the bottom. Never apply too much pressure if there is a lot of resistance.
    댓글 쓰기
  8. HP 225 G7 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Finally, the bottom of the laptop should look like that.
    댓글 쓰기
  9. HP 225 G7 Battery Replacement, Locate and unscrew the 3 screws holding the battery: 9 단계, 이미지 1개 중 1개
    • Locate and unscrew the 3x Philips 1 screws that hold the battery.
    댓글 쓰기
  10. HP 225 G7 Battery Replacement, Remove the battery: 10 단계, 이미지 3개 중 1개 HP 225 G7 Battery Replacement, Remove the battery: 10 단계, 이미지 3개 중 2개 HP 225 G7 Battery Replacement, Remove the battery: 10 단계, 이미지 3개 중 3개
    • After unscrewing the 3 screws, pull the top side of the battery up then slide it out to remove it.
    • Fire Hazard : Always handle lithium batteries with caution.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Stratos Thivaios
회원 가입일: 02/27/23
1,453 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 43
전체 시간: 1,074
