주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 7 1800 Front Facing Camera Replacement
필요한 것
    1. HP 7 1800 Front Facing Camera Replacement, Remove the back panel: 1 단계, 이미지 2개 중 1개 HP 7 1800 Front Facing Camera Replacement, Remove the back panel: 1 단계, 이미지 2개 중 2개
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      댓글 쓰기
    2. HP 7 1800 Front Facing Camera Replacement, Remove the battery: 2 단계, 이미지 3개 중 1개 HP 7 1800 Front Facing Camera Replacement, Remove the battery: 2 단계, 이미지 3개 중 2개 HP 7 1800 Front Facing Camera Replacement, Remove the battery: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      댓글 쓰기
    1. HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: 3 단계, 이미지 2개 중 1개 HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      댓글 쓰기
    2. HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: 4 단계, 이미지 2개 중 1개 HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: 4 단계, 이미지 2개 중 2개
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      댓글 쓰기
    3. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 silver screws from the logic board: 5 단계, 이미지 1개 중 1개
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      댓글 쓰기
    4. HP 7 1800 Front Facing Camera Replacement, Unplug the front facing camera from the logic board: 6 단계, 이미지 1개 중 1개
      • Gently pry the front facing camera plug up and off of the motherboard.
      댓글 쓰기
    5. HP 7 1800 Front Facing Camera Replacement, Remove the logic board: 7 단계, 이미지 1개 중 1개
      • Carefully lift the motherboard directly up.
      댓글 쓰기
    1. HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: 8 단계, 이미지 2개 중 1개 HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: 8 단계, 이미지 2개 중 2개
      • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
      댓글 쓰기
    2. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 black screws on the metal plate: 9 단계, 이미지 1개 중 1개
      • Unscrew the following black screws:
      • Seven 2.82mm Phillips #00 around the metal casing.
      댓글 쓰기
    3. HP 7 1800 Front Facing Camera Replacement, Remove the metal plate: 10 단계, 이미지 1개 중 1개
      • Gently lift the metal plate directly up.
      댓글 쓰기
    4. HP 7 1800 Front Facing Camera Replacement, Remove the camera: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Gently remove the camera from the device with tweezers by lifting it up and out of its square hole.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Trevor Shumate
회원 가입일: 01/21/15
225 평판
안내서 2개를 작성함
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 27
전체 시간: 565
