주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Chromebook 11-v011dx Screen Replacement
필요한 것
    1. HP Chromebook 11-v011dx Screen  Replacement, Key Board: 1 단계, 이미지 3개 중 1개 HP Chromebook 11-v011dx Screen  Replacement, Key Board: 1 단계, 이미지 3개 중 2개 HP Chromebook 11-v011dx Screen  Replacement, Key Board: 1 단계, 이미지 3개 중 3개
      • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
      • Lift up the black rubber cap until it is completely removed.
      • Repeat this until all four of the black rubber caps are removed.
      댓글 쓰기
    2. HP Chromebook 11-v011dx Screen  Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 2 단계, 이미지 2개 중 2개
      • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
      • Lift up the small black rubber cap until it is completely off.
      • Repeat this step one more time to remove the other small black rubber cap on the other side.
      댓글 쓰기
    3. HP Chromebook 11-v011dx Screen  Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
      • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
      댓글 쓰기
    4. HP Chromebook 11-v011dx Screen  Replacement: 4 단계, 이미지 3개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 4 단계, 이미지 3개 중 2개 HP Chromebook 11-v011dx Screen  Replacement: 4 단계, 이미지 3개 중 3개
      • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
      • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
      • Lift the spudger a little in the front of the keyboard until the key board lifts up.
      • With your hands, slowly and carefully lift the key board up.
      댓글 쓰기
    5. HP Chromebook 11-v011dx Screen  Replacement: 5 단계, 이미지 1개 중 1개
      • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
      • Slowly unplug this wire that connects to the key board.
      댓글 쓰기
    1. HP Chromebook 11-v011dx Screen  Replacement, Screen: 6 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement, Screen: 6 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
      댓글 쓰기
    2. HP Chromebook 11-v011dx Screen  Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the wireless card from the motherboard with your own hand.
      댓글 쓰기
    3. HP Chromebook 11-v011dx Screen  Replacement: 8 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 8 단계, 이미지 2개 중 2개
      • Find the wire that connects the screen to the motherboard.
      • Lift black tab that holds the wire in place.
      • Remove the wire.
      댓글 쓰기
    4. HP Chromebook 11-v011dx Screen  Replacement: 9 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 9 단계, 이미지 2개 중 2개
      • Find the display cable that connects the screen to the motherboard.
      • Lift black tab that holds the display cable in place.
      • Remove display cable.
      댓글 쓰기
    5. HP Chromebook 11-v011dx Screen  Replacement: 10 단계, 이미지 3개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 10 단계, 이미지 3개 중 2개 HP Chromebook 11-v011dx Screen  Replacement: 10 단계, 이미지 3개 중 3개
      • Use a Phillips #0 screwdriver to remove the four 1.3mm screws that hold the screen in place.
      • Two screws are on the left of the laptop and two are on the right of the laptop.
      댓글 쓰기
    6. HP Chromebook 11-v011dx Screen  Replacement: 11 단계, 이미지 2개 중 1개 HP Chromebook 11-v011dx Screen  Replacement: 11 단계, 이미지 2개 중 2개
      • Be careful when removing the screen so it doesn't get caught on any wires.
      • Remove the screen from the laptop.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kyle DeMello
회원 가입일: 10/20/17
542 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G2, Julie Fall 2017 UMass Dartmouth, Team S4-G2, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G2
3 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 10
전체 시간: 1,127
