주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement
필요한 것
  1. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 2개
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    댓글 쓰기
  2. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    댓글 쓰기
  3. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 3 단계, 이미지 3개 중 3개
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    댓글 쓰기
  4. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 4 단계, 이미지 1개 중 1개
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    댓글 쓰기
  5. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Set aside the detached keyboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
17다른 기여자 명과 함께
Wilfredo Ramos
회원 가입일: 01/28/15
626 평판
안내서 1개를 작성함
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G2
4 회원들
안내서 8개를 작성함
10가이드 댓글
In the black variant of this model I found that there are two screws under the rubber feet near the hinge.
Justin Cowen - 답글 공유
Super easy repair, keep track of your screws and be very careful with ribbon that connects keyboard and Touch pad.
Terry - 답글 공유
This was very close to a similar HP Chromebook I had to repair recently. Such a beautiful and simple process. I cleaned the keyboard connectors and everything functioned perfectly after I was done. The whole process took about 30 minutes (allotting 10 minutes to find my rubbing alcohol that my wife hid from me).
Josh Bollman - 답글 공유
Any idea how to get the replacement keyboard?
Pawel Wozniak - 답글 공유
At the top of this page under "Relevant parts" there is a link to purchase the keyboard replacement.
Kevin Piper - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 11
지난 30일: 57
전체 시간: 16,817
