주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Chromebook 14-Q010DX Motherboard Replacement
필요한 것
  1. HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 2개
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    댓글 쓰기
  2. HP Chromebook 14-Q010DX Motherboard Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    댓글 쓰기
  3. HP Chromebook 14-Q010DX Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    댓글 쓰기
  4. HP Chromebook 14-Q010DX Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    댓글 쓰기
  5. HP Chromebook 14-Q010DX Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Set aside the detached keyboard.
    댓글 쓰기
  6. HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: 6 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: 6 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: 6 단계, 이미지 3개 중 3개
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    댓글 쓰기
  7. HP Chromebook 14-Q010DX Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Gently remove the speakers.
    댓글 쓰기
  8. HP Chromebook 14-Q010DX Motherboard Replacement, Battery: 8 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement, Battery: 8 단계, 이미지 2개 중 2개
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    댓글 쓰기
  9. HP Chromebook 14-Q010DX Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    댓글 쓰기
  10. HP Chromebook 14-Q010DX Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Gently remove battery.
    댓글 쓰기
  11. HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: 11 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: 11 단계, 이미지 2개 중 2개
    • Using a spudger, remove the white and black cables from the card.
    댓글 쓰기
  12. HP Chromebook 14-Q010DX Motherboard Replacement: 12 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove screw from card.
    댓글 쓰기
  13. HP Chromebook 14-Q010DX Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Gently pull card at a 45° angle to remove it.
    댓글 쓰기
  14. HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: 14 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: 14 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: 14 단계, 이미지 3개 중 3개
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    댓글 쓰기
  15. HP Chromebook 14-Q010DX Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    댓글 쓰기
  16. HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: 16 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: 16 단계, 이미지 2개 중 2개
    • Using your fingers or spudger, pull out the connector.
    댓글 쓰기
  17. HP Chromebook 14-Q010DX Motherboard Replacement: 17 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Motherboard Replacement: 17 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
    댓글 쓰기
  18. HP Chromebook 14-Q010DX Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Gently remove motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kevin Piper
회원 가입일: 01/16/15
1,602 평판
안내서 6개를 작성함
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G2
4 회원들
안내서 8개를 작성함
4가이드 댓글
Can someone just explain for what the sensor board is needed?
martindoerflinger - 답글 공유
Let's the motherboard know when the lid is closed.
Jeff Briedwell - 답글 공유
Hi! How do you start a chrome book from motherboard? Since I am doing a project I need help with that question.... Please send a mail with the explanation on my mail: steffe010929@gmail.con
Stefan - 답글 공유
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
david saldivias - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 24
전체 시간: 5,118
