주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Chromebook 14-Q010DX Speaker Replacement
필요한 것
  1. HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 2개
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    댓글 쓰기
  2. HP Chromebook 14-Q010DX Speaker Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Speaker Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    댓글 쓰기
  3. HP Chromebook 14-Q010DX Speaker Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Speaker Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    댓글 쓰기
  4. HP Chromebook 14-Q010DX Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    댓글 쓰기
  5. HP Chromebook 14-Q010DX Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Set aside the detached keyboard.
    댓글 쓰기
  6. HP Chromebook 14-Q010DX Speaker Replacement, Speaker: 6 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Speaker Replacement, Speaker: 6 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Speaker Replacement, Speaker: 6 단계, 이미지 3개 중 3개
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    댓글 쓰기
  7. HP Chromebook 14-Q010DX Speaker Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Gently remove the speakers.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brandon Nolen
회원 가입일: 01/28/15
3,536 평판
안내서 1개를 작성함
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G2
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 33
전체 시간: 1,461
