주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq 6710b Screen Replacement
필요한 것
  1. HP Compaq 6710b Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
    댓글 쓰기
  2. HP Compaq 6710b Screen Replacement, Keyboard: 2 단계, 이미지 3개 중 1개 HP Compaq 6710b Screen Replacement, Keyboard: 2 단계, 이미지 3개 중 2개 HP Compaq 6710b Screen Replacement, Keyboard: 2 단계, 이미지 3개 중 3개
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    댓글 쓰기
  3. HP Compaq 6710b Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    댓글 쓰기
  4. HP Compaq 6710b Screen Replacement: 4 단계, 이미지 2개 중 1개 HP Compaq 6710b Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    댓글 쓰기
  5. HP Compaq 6710b Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    댓글 쓰기
  6. HP Compaq 6710b Screen Replacement, Power Button Panel: 6 단계, 이미지 1개 중 1개
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
    댓글 쓰기
  7. HP Compaq 6710b Screen Replacement: 7 단계, 이미지 3개 중 1개 HP Compaq 6710b Screen Replacement: 7 단계, 이미지 3개 중 2개 HP Compaq 6710b Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
    댓글 쓰기
  8. HP Compaq 6710b Screen Replacement, Screen: 8 단계, 이미지 1개 중 1개
    • Using a flathead screwdriver, work both sides of the connector next to the fan and take it out.
    댓글 쓰기
  9. HP Compaq 6710b Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Using the T9 Torx screwdriver, remove one 7mm screw on the left hinge.
    • We recommend replacing this screw shortly after removing the cable as it helps hold the hinge to the lower half of the laptop.
    댓글 쓰기
  10. HP Compaq 6710b Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Using the blue plastic opening tool, pull the rubber covers off the screen screws.
    댓글 쓰기
  11. HP Compaq 6710b Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Using a T9 Torx screwdriver, remove the top four 5 mm screws.
    • Remove the bottom two 6 mm screws with the same screwdriver.
    댓글 쓰기
  12. HP Compaq 6710b Screen Replacement: 12 단계, 이미지 3개 중 1개 HP Compaq 6710b Screen Replacement: 12 단계, 이미지 3개 중 2개 HP Compaq 6710b Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Using a flat head screwdriver, pry the plastic panel over the screen up starting at one of the hinges.
    • Using the flathead, continue running the it under the the plastic screen edge and gently pry it off.
    • If you press the screwdriver tip down (by lifting the handle), the screen panel pops off easier.
    댓글 쓰기
  13. HP Compaq 6710b Screen Replacement: 13 단계, 이미지 3개 중 1개 HP Compaq 6710b Screen Replacement: 13 단계, 이미지 3개 중 2개 HP Compaq 6710b Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Slowly pry back the of the screen.
    • It is easiest to work both sides free at the same time.
    댓글 쓰기
  14. HP Compaq 6710b Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Using your fingers, take out the two connections near the hinges.
    댓글 쓰기
  15. HP Compaq 6710b Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Using the T9 Torx screwdriver, unscrew the four 4mm screws.
    댓글 쓰기
  16. HP Compaq 6710b Screen Replacement: 16 단계, 이미지 2개 중 1개 HP Compaq 6710b Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Tilt the screen up from the top to gain access to the screws on the side.
    • Go just far enough to get to the bottom screws to avoid damaging the bracket.
    • Using the PH00 screwdriver, unscrew the 2.5mm screws on the side of the screen. There should be 4 on each side.
    • You can now take out the screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Khulan Orgil
회원 가입일: 04/14/15
1,186 평판
안내서 6개를 작성함
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 회원
CPSU-MANESS-S15S4G2
4 회원들
안내서 6개를 작성함
1가이드 댓글
thank you I found it very interesting
Hassan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 46
전체 시간: 6,221
