주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq 6910p RAM Replacement
필요한 것
    1. HP Compaq 6910p RAM Replacement, RAM: 1 단계, 이미지 2개 중 1개 HP Compaq 6910p RAM Replacement, RAM: 1 단계, 이미지 2개 중 2개
      • Loosen the 1.5 cm Phillips #1 screw.
      • Lift up the cover.
      댓글 쓰기
    2. HP Compaq 6910p RAM Replacement: 2 단계, 이미지 3개 중 1개 HP Compaq 6910p RAM Replacement: 2 단계, 이미지 3개 중 2개 HP Compaq 6910p RAM Replacement: 2 단계, 이미지 3개 중 3개
      • Locate the release latches marked in red.
      • Press down on the release latches simultaneously to release the RAM.
      • Remove the RAM.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tyler Fricks
회원 가입일: 10/22/15
531 평판
안내서 5개를 작성함
Montana Tech, Team 3-2, Shirk Fall 2015 Montana Tech, Team 3-2, Shirk Fall 2015 회원
MTUM-SHIRK-F15S3G2
5 회원들
안내서 50개를 작성함
5가이드 댓글
Can The RAM in this machine run with anything more then just 2GB's? I am just wondering.
Marshall WahlstromHelgren - 답글 공유
This laptop can run even 8gb ram (2x4gb), the second slot is under the keyboard.
Zar' Roc - 답글 공유
How many gb of ram should be put in the back….a 4gb  or can an 8gb ram be inserted in the back so you can not have to put any more under the keyboard if you wanted to just upgrade to 8 gb at one time or 4gb at one time and not ever have to buy 2gb, 4gb or 8gb.  answer me at natefoster@bellsouth.net.  I have in my HP6910p  a 2gb ram and a small 60 harddrive and the computer seems to be slow.  Do I need to increase the ram or the harddrive  or both.  Help me with this.  I am waiting too long to start the computer up.  It is a good computer. What should I do to get more speed.
natefoster - 답글 공유
where´s the second slot located?
Patrick Wirth - 답글 공유
It is under the keyboard. There a few youtube videos showing how to remove the keyboard and get to the second slot.
Dynasty - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 44
전체 시간: 4,363
