주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq Pro 6300 RAM Replacement
    1. HP Compaq Pro 6300 RAM Replacement, RAM: 1 단계, 이미지 2개 중 1개 HP Compaq Pro 6300 RAM Replacement, RAM: 1 단계, 이미지 2개 중 2개
      • Grab the handle and pull, then lift the cover off.
      • Make sure the power cord and other connectors are disconnected before beginning. You should also drain any residual power by pushing the power button after the computer is unplugged.
      댓글 쓰기
    2. HP Compaq Pro 6300 RAM Replacement: 2 단계, 이미지 3개 중 1개 HP Compaq Pro 6300 RAM Replacement: 2 단계, 이미지 3개 중 2개 HP Compaq Pro 6300 RAM Replacement: 2 단계, 이미지 3개 중 3개
      • Grab the tab and pull up the DVD drive to access the RAM.
      댓글 쓰기
    3. HP Compaq Pro 6300 RAM Replacement: 3 단계, 이미지 3개 중 1개 HP Compaq Pro 6300 RAM Replacement: 3 단계, 이미지 3개 중 2개 HP Compaq Pro 6300 RAM Replacement: 3 단계, 이미지 3개 중 3개
      • Put your thumbs on the two tabs surrounding the RAM sticks and push down.
      • This requires a lot of pressure, so don't be afraid to give it some force.
      • If you need more room, you can unplug the SATA cables that connect the hard drive and DVD drive to the computer- just make sure you plug them back in when you finish.
      • Pull the module out by the top or the sides. Take care not to touch the delicate pins at the bottom and the chips on the surface.
      • You may have a different number of modules depending on your configuration. If you have one or more empty slot, you can skip to step 4.
      댓글 쓰기
    4. HP Compaq Pro 6300 RAM Replacement: 4 단계, 이미지 3개 중 1개 HP Compaq Pro 6300 RAM Replacement: 4 단계, 이미지 3개 중 2개 HP Compaq Pro 6300 RAM Replacement: 4 단계, 이미지 3개 중 3개
      • Insert the new module, lining the notch on the module with the notch in the slot.
      • Push down on the module until you hear both tabs lock into the notches.
      • This requires a great deal of pressure, so after you've checked that the notch on the bottom is lined up correctly, don't be afraid to push hard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
907fixer
회원 가입일: 05/23/23
615 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 62
전체 시간: 713
