주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq nc6400 RAM Replacement
필요한 것
  1. HP Compaq nc6400 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug laptop.
    댓글 쓰기
  2. HP Compaq nc6400 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    댓글 쓰기
  3. HP Compaq nc6400 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    댓글 쓰기
  4. HP Compaq nc6400 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Once both the battery locks are unlocked, slide the battery out to remove.
    댓글 쓰기
  5. HP Compaq nc6400 RAM Replacement, RAM: 5 단계, 이미지 2개 중 1개 HP Compaq nc6400 RAM Replacement, RAM: 5 단계, 이미지 2개 중 2개
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
    댓글 쓰기
  6. HP Compaq nc6400 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
    댓글 쓰기
  7. HP Compaq nc6400 RAM Replacement: 7 단계, 이미지 2개 중 1개 HP Compaq nc6400 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
    댓글 쓰기
  8. HP Compaq nc6400 RAM Replacement: 8 단계, 이미지 1개 중 1개
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
    댓글 쓰기
  9. HP Compaq nc6400 RAM Replacement: 9 단계, 이미지 2개 중 1개 HP Compaq nc6400 RAM Replacement: 9 단계, 이미지 2개 중 2개
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Luis Vazquez
회원 가입일: 09/24/13
401 평판
안내서 2개를 작성함
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 회원
CPSU-FORTE-F13S14G6
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 33
전체 시간: 4,869
