주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq nc8430 Fan Replacement
필요한 것
  1. HP Compaq nc8430 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
    댓글 쓰기
  2. HP Compaq nc8430 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Slide up against the three lines the battery has.
    댓글 쓰기
  3. HP Compaq nc8430 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
    댓글 쓰기
  4. HP Compaq nc8430 Fan Replacement, Fan: 4 단계, 이미지 1개 중 1개
    • Use a J1 screwdriver to remove each screw on the bottom of the computer. This will allow for the opening of the laptop to gain access to the fan.
    댓글 쓰기
  5. HP Compaq nc8430 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Now that you have unscrewed most of the bottom of the laptop, carefully flip it back over.
    • Press down firmly on the four latches shown in the photo to detach the key board. This will unlock the latches holding the keyboard down, doing this will grant you access to the inside of the computer.
    댓글 쓰기
  6. HP Compaq nc8430 Fan Replacement: 6 단계, 이미지 2개 중 1개 HP Compaq nc8430 Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the keyboard carefully now that it is detached, and use the pry tool to assist you in the removal of the keyboard.
    댓글 쓰기
  7. HP Compaq nc8430 Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Now your laptop should have no screws and no keyboard.
    • You should now be able to open up the base of the laptop. With a bit of force, detach the sides latches of the base by pulling them open carefully.
    • Your computer should now look like the provided photo, where you can see where the fan is located.
    댓글 쓰기
  8. HP Compaq nc8430 Fan Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq nc8430 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove fan by detaching the blue and white plug from the main socket.
    • Continue to unscrew all screws to completely disassemble to gain complete access to the computer's fan.
    댓글 쓰기
  9. HP Compaq nc8430 Fan Replacement: 9 단계, 이미지 1개 중 1개
    • As an extra precaution, please check for any dirt or debris that are preventing the fans complete functionality.
    • Use a cotton swab and alcohol to clean the fan before re attaching it to ensure smooth functioning of the fan.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andrea Funes
회원 가입일: 03/22/17
149 평판
안내서 1개를 작성함
Texas Tech, Team S13-G4, Bennett Spring 2017 Texas Tech, Team S13-G4, Bennett Spring 2017 회원
TTU-BENNETT-S17S13G4
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 30
전체 시간: 1,672
