주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq nc8430 LCD Screen Replacement
필요한 것
  1. HP Compaq nc8430 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
    댓글 쓰기
  2. HP Compaq nc8430 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide up against the three lines the battery has.
    댓글 쓰기
  3. HP Compaq nc8430 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
    댓글 쓰기
  4. HP Compaq nc8430 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
    • Remove the four 1.2mm Phillip #1 screws circled.
    • The laptop may have rubber covers over the screws,. Remove them using a pointed tool to pry them out.
    댓글 쓰기
  5. HP Compaq nc8430 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 HP Compaq nc8430 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Pry up the plastic screen cover with the pry tool.
    • Once a corner of the plastic screen cover is lifted, slide the pry tool around the entire screen until the screen is completely lifted from the base.
    댓글 쓰기
  6. HP Compaq nc8430 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 1.2 Phillips screws circled.
    댓글 쓰기
  7. HP Compaq nc8430 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 1.2mm Phillip screws circled.
    댓글 쓰기
  8. HP Compaq nc8430 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift the monitor, from the base of the laptop.
    • The laptop will still be connected to the monitor wires located at the bottom of the screen.
    댓글 쓰기
  9. HP Compaq nc8430 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 HP Compaq nc8430 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the video cable wires.
    • Gently remove the video cables from the sensor board with tweezers.
    댓글 쓰기
  10. HP Compaq nc8430 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • All cables should be disconnected from the sensor board. Remove the eight 2mm Phillip screws attaching the bezel to the side of the monitor.
    • Attach the bezel to the new replacement screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Corey Nickerson II
회원 가입일: 03/20/17
135 평판
안내서 1개를 작성함
Texas Tech, Team S13-G4, Bennett Spring 2017 Texas Tech, Team S13-G4, Bennett Spring 2017 회원
TTU-BENNETT-S17S13G4
5 회원들
안내서 5개를 작성함
1가이드 댓글
Could you please charge it using USB.
Cato Nicolai Lund - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 20
전체 시간: 1,145
