주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Deskjet F4480 Scanner Light Replacement
필요한 것
    1. HP Deskjet F4480 Scanner Light Replacement, Front: 1 단계, 이미지 1개 중 1개
      • Open the front access panel by placing your finger in the front slot and pulling gently.
      댓글 쓰기
    1. HP Deskjet F4480 Scanner Light Replacement, Top Lid: 2 단계, 이미지 1개 중 1개
      • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
      댓글 쓰기
    2. HP Deskjet F4480 Scanner Light Replacement: 3 단계, 이미지 3개 중 1개 HP Deskjet F4480 Scanner Light Replacement: 3 단계, 이미지 3개 중 2개 HP Deskjet F4480 Scanner Light Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the four 9mm T10 Torx screws on the top.
      댓글 쓰기
    3. HP Deskjet F4480 Scanner Light Replacement: 4 단계, 이미지 2개 중 1개 HP Deskjet F4480 Scanner Light Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully lift the top panel off of the printer.
      • Do not tear or damage the two cables that connect the top lid to the motherboard.
      댓글 쓰기
    4. HP Deskjet F4480 Scanner Light Replacement: 5 단계, 이미지 3개 중 1개 HP Deskjet F4480 Scanner Light Replacement: 5 단계, 이미지 3개 중 2개 HP Deskjet F4480 Scanner Light Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
      댓글 쓰기
    1. HP Deskjet F4480 Scanner Light Replacement, Remove Back Panel of Lid: 6 단계, 이미지 1개 중 1개
      • Remove one 9mm T10 Torx screw from the back of the printer lid.
      댓글 쓰기
    2. HP Deskjet F4480 Scanner Light Replacement: 7 단계, 이미지 2개 중 1개 HP Deskjet F4480 Scanner Light Replacement: 7 단계, 이미지 2개 중 2개
      • Press outward on the plastic tab holding the back panel in place.
      댓글 쓰기
    3. HP Deskjet F4480 Scanner Light Replacement: 8 단계, 이미지 2개 중 1개 HP Deskjet F4480 Scanner Light Replacement: 8 단계, 이미지 2개 중 2개
      • Pull the back panel towards you and lift it away from the rest of the printer cover.
      • Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
      댓글 쓰기
    1. HP Deskjet F4480 Scanner Light Replacement, Scanner Light: 9 단계, 이미지 2개 중 1개 HP Deskjet F4480 Scanner Light Replacement, Scanner Light: 9 단계, 이미지 2개 중 2개
      • Remove scanner bar from track inside lid.
      • Do not try to detach the large ribbon cable. It is not designed to be removed from the scanner bar. Also do not try to pull ribbon cable out of the lid.
      댓글 쓰기
    2. HP Deskjet F4480 Scanner Light Replacement: 10 단계, 이미지 1개 중 1개
      • Remove two 9mm T10 Torx screws from the scanner bar to release scanner light.
      댓글 쓰기
    3. HP Deskjet F4480 Scanner Light Replacement: 11 단계, 이미지 1개 중 1개
      • Separate the scanner light from the rest of the scanner bar.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Tim
회원 가입일: 01/15/13
193 평판
안내서 4개를 작성함
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 회원
CPSU-REGAN-W13S18G35
5 회원들
안내서 64개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 48
전체 시간: 4,335
