주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteBook 1050 G1 Key Replacement
필요한 것
    1. HP EliteBook 1050 G1 Key Replacement, Key: 1 단계, 이미지 1개 중 1개
      • Find the broken or malfunctioning key on the keyboard.
      • In this guide, we will replace the "ctrl" key, but this guide works for all keys on the keyboard.
      댓글 쓰기
    2. HP EliteBook 1050 G1 Key Replacement: 2 단계, 이미지 2개 중 1개 HP EliteBook 1050 G1 Key Replacement: 2 단계, 이미지 2개 중 2개
      • Wedge the spudger under the corner of the key and pry up while moving the spudger along the length of one edge of the key.
      • Repeat this process for three sides of the key you are removing.
      • No matter how gently you attempt to remove the key, it will sound like it is breaking when you pry and remove it from its housing. THIS IS OKAY. The plastic brackets HP uses to keep its keys in place are very loud, but also very durable.
      댓글 쓰기
    3. HP EliteBook 1050 G1 Key Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the key manually by the the edge opposite the one side of the key you did not pry off with the spudger.
      • To ensure the easiest possible removal, lift the key up while gently pulling away from the edge that is still in the keyboard.
      댓글 쓰기
    4. HP EliteBook 1050 G1 Key Replacement: 4 단계, 이미지 1개 중 1개
      • To replace the key, lay the new key over its housing with the proper orientation and push it down until you hear a click.
      • If the key is not broken, just "sticky" or malfunctioning, procced up to this step. You can now wiggle the white silicon portion of the key's interior around, pushing down on the extended part of the silicon and wiggling it back and forth. Once you have done that, you can replace the key as described above.
      • Furthermore, you can remove any debris from under the keys at this time with a toothpick or a dampened q-tip, which may improve the performance of your keys.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jacob Osecheck
회원 가입일: 04/15/19
279 평판
안내서 2개를 작성함
Cal Poly, Team S2-G10, Maness Spring 2019 Cal Poly, Team S2-G10, Maness Spring 2019 회원
CPSU-MANESS-S19S2G10
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 39
지난 30일: 174
전체 시간: 9,871
