주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteBook 8530w Fan Replacement
필요한 것
    1. HP EliteBook 8530w Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP EliteBook 8530w Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Turn the laptop off then place it down so that the back is facing up.
      • Slide the battery release switch to the left and hold it there.
      댓글 쓰기
    2. HP EliteBook 8530w Fan Replacement: 2 단계, 이미지 2개 중 1개 HP EliteBook 8530w Fan Replacement: 2 단계, 이미지 2개 중 2개
      • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
      • Once the battery is removed from the laptop, you may release the switch.
      • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
      댓글 쓰기
    1. HP EliteBook 8530w Fan Replacement, Fan: 3 단계, 이미지 1개 중 1개
      • Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
      • These screws should have a keyboard icon stamped next to them.
      댓글 쓰기
    2. HP EliteBook 8530w Fan Replacement: 4 단계, 이미지 3개 중 1개 HP EliteBook 8530w Fan Replacement: 4 단계, 이미지 3개 중 2개 HP EliteBook 8530w Fan Replacement: 4 단계, 이미지 3개 중 3개
      • Flip the laptop over then open the lid.
      • Slide the four tabs at the top of the keyboard towards you with your finger.
      • Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
      • Do not try to pull the keyboard out of the laptop. There are still cables connected to it that can easily be damaged.
      댓글 쓰기
    3. HP EliteBook 8530w Fan Replacement: 5 단계, 이미지 3개 중 1개 HP EliteBook 8530w Fan Replacement: 5 단계, 이미지 3개 중 2개 HP EliteBook 8530w Fan Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
      • Gently remove the fan connector that plugs into the motherboard.
      • Note: It can help to use something like tweezers to remove the connector if you are having trouble.
      • Remove the fan.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 1,050
