주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G6 Battery Replacement
필요한 것
  1. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the back cover: 1 단계, 이미지 1/1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Battery Replacement, Release the clips: 2 단계, 이미지 1/2 HP EliteBook x360 830 G6 Battery Replacement, Release the clips: 2 단계, 이미지 2/2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: 3 단계, 이미지 1/2 HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: 3 단계, 이미지 2/2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: 4 단계, 이미지 1/3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: 4 단계, 이미지 2/3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: 5 단계, 이미지 1/3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: 5 단계, 이미지 2/3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: 5 단계, 이미지 3/3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the battery: 6 단계, 이미지 1/1
    • Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  7. HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: 7 단계, 이미지 1/3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: 7 단계, 이미지 2/3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: 7 단계, 이미지 3/3
    • Pull the battery out from the retaining tabs at the front of the chassis.
    • Remove the battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
회원 가입일: 09/19/22
70,411 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,103개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 67
전체 시간: 2,064
