주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteOne 800 G1 Fan Assembly Replacement
필요한 것
  1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 1개 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 2개 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 3개
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
    댓글 쓰기
  2. HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: 2 단계, 이미지 2개 중 1개 HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: 2 단계, 이미지 2개 중 2개
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
    댓글 쓰기
  3. HP EliteOne 800 G1 Fan Assembly Replacement: 3 단계, 이미지 2개 중 1개 HP EliteOne 800 G1 Fan Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
    댓글 쓰기
  4. HP EliteOne 800 G1 Fan Assembly Replacement: 4 단계, 이미지 2개 중 1개 HP EliteOne 800 G1 Fan Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
    댓글 쓰기
  5. HP EliteOne 800 G1 Fan Assembly Replacement, Fan Assembly: 5 단계, 이미지 1개 중 1개
    • Disconnect these two power connectors on the motherboard, one connector is white and the other is black. You can identify the correct wires by their braided colors: red, yellow, blue, and black.
    댓글 쓰기
  6. HP EliteOne 800 G1 Fan Assembly Replacement: 6 단계, 이미지 2개 중 1개 HP EliteOne 800 G1 Fan Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Torx T15 driver to remove the three 6mm screws surrounding the fan assembly.
    • Pull the fan assembly up from the case to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Michael Ewing
회원 가입일: 10/01/15
1,071 평판
안내서 4개를 작성함
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 회원
CPSU-MANESS-F15S1G24
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 37
전체 시간: 7,451
