주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Elitebook 8460p Keyboard Replacement
필요한 것
    1. HP Elitebook 8460p Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
      댓글 쓰기
    2. HP Elitebook 8460p Keyboard Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the battery away from the switches until it can be lifted away from the laptop.
      • Lift the battery away from the laptop.
      댓글 쓰기
    1. HP Elitebook 8460p Keyboard Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
      • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
      댓글 쓰기
    2. HP Elitebook 8460p Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Slide the back shell of the laptop away from the switches until it can be lifted up.
      • Lift the shell straight up.
      댓글 쓰기
    1. HP Elitebook 8460p Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 1개 HP Elitebook 8460p Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 2개 HP Elitebook 8460p Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 3개
      • Attach ESD strap around your wrist and to a ground.
      • Using a Phillips #0 bit, unscrew the two screws in front of the battery slot located on the bottom of the laptop.
      댓글 쓰기
    2. HP Elitebook 8460p Keyboard Replacement: 6 단계, 이미지 1개 중 1개
      • Flip the laptop over and open the screen.
      댓글 쓰기
    3. HP Elitebook 8460p Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP Elitebook 8460p Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP Elitebook 8460p Keyboard Replacement: 7 단계, 이미지 3개 중 3개
      • Using a spudger, work around the edge of the keyboard and pry it up from the device.
      댓글 쓰기
    4. HP Elitebook 8460p Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP Elitebook 8460p Keyboard Replacement: 8 단계, 이미지 2개 중 2개
      • Lift the keyboard out of the laptop and flip it over.
      • This exposes two different connectors. Both need to be detached in order to remove the keyboard. The larger connector is the main keyboard cable.
      댓글 쓰기
    5. HP Elitebook 8460p Keyboard Replacement: 9 단계, 이미지 2개 중 1개 HP Elitebook 8460p Keyboard Replacement: 9 단계, 이미지 2개 중 2개
      • Disconnect the keyboard cable on the laptop using a thin pry tool to open the connection.
      • Open the connection by inserting a thin plastic pry tool under the black tab in the connector and flipping it up.
      댓글 쓰기
    6. HP Elitebook 8460p Keyboard Replacement: 10 단계, 이미지 2개 중 1개 HP Elitebook 8460p Keyboard Replacement: 10 단계, 이미지 2개 중 2개
      • Using the spudger again, disconnect the thin ribbon strip on the back of the keyboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,313 평판
안내서 10개를 작성함
2가이드 댓글
There's a third keyboard screw right beside the fan
Colin Chaplin - 답글 공유
yeah just wanted to say this ...
Also the screws are PH1 not PH0
Robert Kohari - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 61
전체 시간: 5,031
