주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 4-1105dx Display Replacement
필요한 것
    1. HP Envy 4-1105dx Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Power off the device before beginning disassembly. Disconnect all external devices.
      • Flip the device on its back.
      댓글 쓰기
    2. HP Envy 4-1105dx Display Replacement: 2 단계, 이미지 1개 중 1개
      • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
      댓글 쓰기
    3. HP Envy 4-1105dx Display Replacement: 3 단계, 이미지 1개 중 1개
      • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
      댓글 쓰기
    4. HP Envy 4-1105dx Display Replacement: 4 단계, 이미지 1개 중 1개
      • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
      댓글 쓰기
    5. HP Envy 4-1105dx Display Replacement: 5 단계, 이미지 1개 중 1개
      • Once the device is open, move the ribbon cable to the side.
      댓글 쓰기
    6. HP Envy 4-1105dx Display Replacement: 6 단계, 이미지 1개 중 1개
      • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
      댓글 쓰기
    7. HP Envy 4-1105dx Display Replacement: 7 단계, 이미지 1개 중 1개
      • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
      댓글 쓰기
    8. HP Envy 4-1105dx Display Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the battery up and remove.
      • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
      댓글 쓰기
    1. HP Envy 4-1105dx Display Replacement, Display: 9 단계, 이미지 3개 중 1개 HP Envy 4-1105dx Display Replacement, Display: 9 단계, 이미지 3개 중 2개 HP Envy 4-1105dx Display Replacement, Display: 9 단계, 이미지 3개 중 3개
      • Close the device and turn it right-side up. Locate the two screw covers on the left and right side base of the display panel.
      • Remove the screw covers, using the black plastic spudger.
      • Remove the two 3.0 mm Phillips-front screws on the left and right hinges that secure the display panel to the computer, using a Phillips #1 screwdriver.
      댓글 쓰기
    2. HP Envy 4-1105dx Display Replacement: 10 단계, 이미지 3개 중 1개 HP Envy 4-1105dx Display Replacement: 10 단계, 이미지 3개 중 2개 HP Envy 4-1105dx Display Replacement: 10 단계, 이미지 3개 중 3개
      • Pry open the plastic bezel case of the device using the plastic spudger. If the plastic spudger doesn't work, carefully use the metal spudger.
      • Loosen the edges of the case from all four sides of the display panel.
      • Be careful not to use hands while opening, as the edges of the back case are sharp.
      • Once the back case pops out, close the laptop exposing the back display.
      댓글 쓰기
    3. HP Envy 4-1105dx Display Replacement: 11 단계, 이미지 2개 중 1개 HP Envy 4-1105dx Display Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the four 4.0 mm Phillips display panel screws using Phillips #1 screwdriver.
      • Remove the four 2.0 mm Phillips screws using Phillips #00 screwdriver.
      댓글 쓰기
    4. HP Envy 4-1105dx Display Replacement: 12 단계, 이미지 3개 중 1개 HP Envy 4-1105dx Display Replacement: 12 단계, 이미지 3개 중 2개 HP Envy 4-1105dx Display Replacement: 12 단계, 이미지 3개 중 3개
      • Remove the four 4.0 mm Phillips silver screws on the hinges using a Phillips #1 screw driver.
      • Remove the two 6.0 mm Phillips black hinge cover screws using a Phillips #0 screw driver.
      • Flip and remove the hinge covers using a plastic spudger.
      • While flipping, be careful not bend the screen brackets.
      댓글 쓰기
    5. HP Envy 4-1105dx Display Replacement: 13 단계, 이미지 2개 중 1개 HP Envy 4-1105dx Display Replacement: 13 단계, 이미지 2개 중 2개
      • Disconnect the ribbon cable on the bottom of the display panel using a plastic spudger.
      • Disconnect the adjacent golden LCD connector using a plastic spudger.
      댓글 쓰기
    6. HP Envy 4-1105dx Display Replacement: 14 단계, 이미지 1개 중 1개
      • Remove the golden tape adhering to the display panel using a plastic spudger.
      댓글 쓰기
    7. HP Envy 4-1105dx Display Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the white color wifi antennas from the display panel using a plastic spudger.
      댓글 쓰기
    8. HP Envy 4-1105dx Display Replacement: 16 단계, 이미지 3개 중 1개 HP Envy 4-1105dx Display Replacement: 16 단계, 이미지 3개 중 2개 HP Envy 4-1105dx Display Replacement: 16 단계, 이미지 3개 중 3개
      • Separate the transparent plastic tape that covers the circuit board using hands.
      • Carefully flip the circuit board.
      • Remove the black tape adhering to the green circuit board that is connected to the display panel.
      댓글 쓰기
    9. HP Envy 4-1105dx Display Replacement: 17 단계, 이미지 2개 중 1개 HP Envy 4-1105dx Display Replacement: 17 단계, 이미지 2개 중 2개
      • Using a plastic prying tool, remove the display panel.
      • This is the disassembled screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Parvathy Nambidi
회원 가입일: 05/17/17
306 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 1,287
