주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 5660 Scanner Glass Replacement
필요한 것
    1. HP Envy 5660 Scanner Glass Replacement, Scanner Glass: 1 단계, 이미지 1개 중 1개
      • Open the cartridge access area.
      댓글 쓰기
    2. HP Envy 5660 Scanner Glass Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the three 11.5 mm screws with a T10 bit.
      댓글 쓰기
    3. HP Envy 5660 Scanner Glass Replacement: 3 단계, 이미지 3개 중 1개 HP Envy 5660 Scanner Glass Replacement: 3 단계, 이미지 3개 중 2개 HP Envy 5660 Scanner Glass Replacement: 3 단계, 이미지 3개 중 3개
      • Locate the cover hinge on the right side of the printer.
      • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
      댓글 쓰기
    4. HP Envy 5660 Scanner Glass Replacement: 4 단계, 이미지 2개 중 1개 HP Envy 5660 Scanner Glass Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the 12 mm screws on the left side of the printer with a T10 bit.
      댓글 쓰기
    5. HP Envy 5660 Scanner Glass Replacement: 5 단계, 이미지 2개 중 1개 HP Envy 5660 Scanner Glass Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
      • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
      댓글 쓰기
    6. HP Envy 5660 Scanner Glass Replacement: 6 단계, 이미지 3개 중 1개 HP Envy 5660 Scanner Glass Replacement: 6 단계, 이미지 3개 중 2개 HP Envy 5660 Scanner Glass Replacement: 6 단계, 이미지 3개 중 3개
      • Pull the plastic side cover off of the printer.
      • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
      • Plastic opening tools or a metal spudger may also be used.
      댓글 쓰기
    7. HP Envy 5660 Scanner Glass Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the five 11.5 mm screws located at the bottom of the scanner.
      • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
      • The top of the scanner will now easily pull off.
      댓글 쓰기
    8. HP Envy 5660 Scanner Glass Replacement: 8 단계, 이미지 2개 중 1개 HP Envy 5660 Scanner Glass Replacement: 8 단계, 이미지 2개 중 2개
      • Pry the old scanning glass up with a metal spudger.
      • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan Steakley
회원 가입일: 01/23/18
790 평판
안내서 5개를 작성함
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G6
4 회원들
안내서 10개를 작성함
1가이드 댓글
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
Rich Monell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 2,023
